20 Most Recent
Toshiba 20AF44 20" TV Questions & Answers
What remote can i use for my toshiba 20af44 TV
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141 These are the setup codes for Toshiba TV, with universal remote control. Just buy one universal remote control, which have these setup codes. Brand isn't a matter. You can get this detail, by the code list, the remote control will have.
I have a video game
If you feel you need a universal remote, I would suggest the Phiilps remote model#SRP1003. This model number is located near the UPC code. If you feel you need an original, see Matelectronic.com or MCM Electronics.com. Thanks for asking and show all hands of support!
Toshiba mo#20af44 hooking up 360 xbox
As far as I'm aware, the only way to switch inputs on the TV is by using the Toshiba remote--there aren't buttons on the TV itself to do it. Which means unfortunately, if nothing on your universal remote will do so and you don't have the Toshiba remote (either to use or to reprogram your universal remote with), you may be out of luck.
Can you tell me if
if the tv has a cable ready hook up then it can produce digital the trick is if your tv have satellite or a cable service then you don't need the convertor box but if you don't have none of these services then you will need a convertor box and if you have service provider and the service gets cancelled then you will need the convertor box
Tv won't turn on
you probably got a power surge and could have blown an internal fuse or the power supply was damaged. If you know about troubleshooting electronic curcuits then your gonna first need a schematic diagram and that can be gotten from sams photo facts They have almost any tv diagramand is downloadable too. If you dont under stand how the set works then I would advise a pro taking a look at it as it could be a current limiter resistor or a regulator IC .. Good Luck
Toshiba mo# 20AF44/xbox360 ISSUE
Just because a TV has RGB component inputs does not mean
HI-Def will work......Component range = 480 to 720 to 1080....
You can download owners manual off web..Toshiba.com..
click on HDTV then click customer support....owners manual.
............................................................................T.
No sound on channel 7
In audio menu, find selection for SAP and change to stereo...
Let me know if more help needed, provide Model #..........T.
