Apex Digital Televison & Video • Uploaded on Sep 29, 2013
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
39 questions posted
193 Questions
97 Questions
59 Questions
