20 Most Recent
TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G) Questions & Answers
How can restart TL-WA5210G when lose ip and restart buttom
From what I understand, your device enables you to connection to an open network on a long range distance. Impressive. This device looks like is it most effective with no objects (buildings, trees,ETC..) in the way. I wouldn't try to reset the device. adjustments must be made. Consider the remote network you are connecting to. The owner of that network may turn off the wifi signal also control a limited amount of IP addresses it assigns (devices). Personally, I like having my own network without having to rely on someone
else's control of there network. The admin of that network could even restrict certain sites to be viewed or used.
How can I open the page
Locate your router. There should be a label which displays your default gateway. The Default gateway displays a number. It should show a number like
- 192.168.0.1
- 192.168.1.1
- 10.0.0.1
Open your browser (Internet Explorer, Chrome, ETC..) Type the default gateway number into the search engine text box on top of the screen press enter or return (mac). The page should now show user name and password. Locate the router and locate the default credentials. For example. most routers requires the user name to be blank and the password is password. Routers very.
About obtaining an IP address. Routers are usually set to option the IP address automatically unless you manually set a static IP address which is not recommended.
Resetting the username and password
you can reset by tow ways :
first from configure router page .
second , if you didnt remember old usr & pass , connect directely through ethernet ,, or reset AP
Tp-link tlwa5210g wireless single not flashing
check SSID , if shown ,, the problem with electricity ,, if not shown ,, check antina , if not shown ,, reset AP ,, configure agian ,, if not shown ,, replace AP
Wireless signal light not flashing
wireless not flashing ,, may be some reasons :
1- if there is a signal and its SSID shown , i think problem with electricity led .
2- if there no signal and its SSID doesnt shown , check antina if putting successfully , if not check configuration ,, if not reset AP ,, if not replace it
How i can change ip address of tp link 5210g throw ethernet cable
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
Need to sync HP2003AV
Powerline adapters will most likely need to be on the same phase of your electrical hook-up. Try another wall outlet.
How can i change the username and password for
If you know the current one, just login to the admin interface, find the 'SECURITY' section and reset it to whatever you want. If you do not know it, you will need to reset the router (usually a simple push-button on the bottom or back - press and hold for a few seconds) and then login using the default login/password for the router and start over.
I could not loged in
Turn off the router.
Press and hold small reset button (usually with a pin or pen) for 1 minute.
While still holding the reset button, turn the router back on and keep holding reset button for 30 seconds.
This will completely reset your router. The username/password will be set to default. (Usually Admin/Admin)
