20 Most Recent
Hitachi 57S500 57" Rear Projection Television Questions & Answers
How do you seperate the
Separation from the speakers (what I assume you're asking) is generally not possible on televisions such as this one. The projection lenses are actually in that area.
Can you still get most parts for 57s500 like blubs
Yes,very limited parts left for old design DLP tvs.Tries websites Ebay.com or Amazon.com to buy a used LCD tv.Like a Samsung have a good priced for used LCD tv around $700-750 for a "46 inches.Cosmaticly probally have some scratches,dents or may a crack on it out bazel frame,but the Tv LCD screen 100% good and it electronic circuitries boards too.
About a 1/4 of the
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
57 inch projection Screen that the front has been
Yes it can, but it has at least two screens and most Hitachi sets only sell them as a pair----Call Andrews Electronics in California--they have an 800 number---Give them model number and they will give you price and availability for the screen unit.
The only option I have used is search EBAY etc or I use CRAIGSLIST to look for an identical model that has the screen but the set does not work.
I did this for a customer with a 65 inch Mitsubishi---screens were about 400 but we found an identical set and picked it up for 50.
Let me know if you have questions or need advice by making a comment here.
If this helped or told you something you did not know please rate this solution as very helpful as I do this here for free.
SD TECH
I AM LOOKING FOR A
I found a website tvscreenrepair.com. They might be able to help you. You can email them at tvscreenfinder.com.
Or you need to call Hitachi direct.
How hard is it to open up a Hitachi 57: Rear
there are just a series of screws to remove the the back and the whole thing opens up. Not sure what to have you used to clean the bulbs off probably just a clean soft electronics cloth. No alchol or windex.
Out of alignment
If it is a convergence problem it would probably run around 250
unless somebody was trying to rip you off
I would get it and install the convergence kit
