20 Most Recent
Samsung NP-N110 Netbook Questions & Answers
Screen is dim when power not plugged in
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Where is the power button?
I think it is on the side where the hinges for the screen are. Actually turn it sideways and look at the hinges
I deleted samsung recovery solution 4,from internal hard drive i'd tried to reformat but can't,how an i get the recovery solution 4?
there is 5 step's to reformat you'r Samsung recovery 4 .
A Data Restore reloads files that you have previously backed up using a Data Backup.
To perform a Data Restore, follow these steps:
- Tap the F4 Key at the Samsung logo when you first power on the computer. This method would be used if the computer powers on, but Windows does not load.
- Click Agree to accept the Licensing Agreement. Samsung Recovery Solution 4 loads. If you close the Licensing Agreement dialog Samsung Recovery Solution 4 will close without making any changes.
- Once Samsung Recovery Solution 4 loads, click Restore. The Restore dialog appears.
- Click Data Restore. The Restore > Data Restore dialog appears.
- On Restore > Data Restore dialog, there is a list of backups created using Data Backup. If no backups have been created, the list will be empty. Select the backup you would like to use for this restore, and uncheck any items you do not want to restore. When you are finished, click Next.
- Samsung Recovery Solution 4 displays a window offering two choices. After making a selection, click Next .
- Samsung Recovery Solution 4 prompts you to confirm the restore. Click Yes to continue.
- Samsung Recovery Solution 4 displays a progress bar to show you the current progress of the restore.
- After the Data Restore is complete, Samsung Recovery Solution 4 prompts you to click OK.
- Click OK to complete the restore.
- Click Detail >> for detailed information on any data restore errors.
- After you've clicked OK, the Data restore is complete. Close Samsung Recovery Solution 4.
2/23/2016 7:38:49 AM •
Samsung N...
Answered
on Feb 23, 2016
VGA CONNECTION TO A SAMSUNG TV NO SIGNAL
have you tryed re,tuneing your tv to see if it finds your vga cable.
or try going into your av menu on your tv and it should give you a list of ext1 or ext2 and so on.or try hdmi 1.hdmi 2,and so on.
4/9/2015 10:22:41 PM •
Samsung N...
Answered
on Apr 09, 2015
Pv420 bios pasword
avoid be misunderstood, read this about ... http://www.wikihow.com/Clear-BIOS-Password
4/6/2015 8:31:31 PM •
Samsung N...
Answered
on Apr 06, 2015
