20 Most Recent
Soltek SL-75FRV Motherboard Questions & Answers
Not have mixer harware sound driver
Get onlineand got to www.google.com In the google search box type: "SoltekSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.You can also try Driver Guide at:http://www.driverguide.comTry using the VLC Player. It comes with drivers and codec. I've seen it solve many sound issues.Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Hi,i changed my OS from
You need to go google search for windows 7 drivers for your respected pieces of hardware.
Unfortunately, not all Windows XP drivers are compatible with Windows 7
No sound
You will have to download the driver from the mfr.'s website.
There are other sources but often they do not have the most recent version.
Audio driver not loaded
You need to install the VIA drivers from the Mainboard driver CD first, then the Audio driver on the same CD. Do it in that order!
Soltek 75frv
I had this problem. The sound driver is on the Soltek Mainboard Driver CD that comes with the motherboard. I am pretty sure you have to install the VIA drivers first - the order of installation is important. Hope this helps.
Disabling Bios Writing Protection
Sometimes the BIOS calls this protection some sort of "virus protection" as past viruses, like the CIH virus would tend to overwrite motherboard BIOS' with jargon, bricking the motherboard.
Try disabling any onboard "virus" protection and try flashing your BIOS again.
Sl-75frv memorys
Dear Sir,
You can install upto 3 GB RAM. i.e. 1GB PC3200 DIMM RAM in each slot.
Please go to BIOS settings & load the defaults. / check following. BIOS settings.
DIMM clock & timing is auto/ detected by SPD (Serial Presence Detect)
Possibly the 1GB RAM you are trying to install does not have SPD / is faulty. Try with a new / working 1 GB RAM.
Hope this helps you friend...
Motherboard
Processor
- Supports Socket-A AMD processors (Athlon/Duron)
- Supports FSB 200/266/333MHz
Rate me SOLVED
Few Problem Infinity Loop
MEMORY PROBLEMS
FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP
Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem.
You can also try the following methods.
Turn off power, Unplug. Remove the cover of your PC.
Remove the memory from the Motherboard. Note on the locks!
Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser.
It should be shiny gold.
Reseat your memory to the motherboard and Test!
If you are having trouble with Newly bought items save your self from headaches by returning them and
demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
BIOS DISPLAYING INCORRECT CPU SPEED
I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties.
To upgrade the BIOS:
1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown;
2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such.
Hope this be of some help/idea. Post back how things are or should you need further information.
Good luck and kind regards.
