20 Most Recent
Soltek SL-65KV2-T Motherboard Questions & Answers
SL-65KV2-CT manual
open your web browser
open the site google and search for it
Please rate me>Kartaela ;-)
4/11/2009 1:30:16 PM •
Soltek...
Answered
on Apr 11, 2009
Mainboard SL-65KV2-CT
yes i told you that but i change my mind
throw your computer upside down
and after that buy my computer
Pentium 1 75 mghz
24 mb ram
640 mb hdd
1mb vga
12/21/2008 5:06:33 PM •
Soltek...
Answered
on Dec 21, 2008
RE SETTING CMOS
Dear Customer,
Dont reply to system like this cause its too much ssensetive chips so sometimes it make more prob to you with more & more,
jsut clean up your board with smooth air pressure,or light vacumes,
than reconnect monitor & all hardware,
you wil be seen your system batter worked.
TTHNX
5/19/2008 1:23:30 PM •
Soltek...
Answered
on May 19, 2008
Soltek SL-65KV2 Motherboard Drivers
ok,
i am giving you 1 link for your motherboard driver,download & use it
as you finished this article reading you wil get your driver at your drive,
DLL
http://www.driver-central.com/download-11056-4607.html
5/16/2008 12:41:08 PM •
Soltek...
Answered
on May 16, 2008
PROBLEM WITH MONITOR NOT SWITCHING ON ON SOLTEK SL-65KVB/KV2 MOTHERBOARD
Hi, does the pc load up to bios and does the pc power up, how did you reset cmos was it by the jumper or by the battery if you done one try the other. If none of that works, you may off blew or damages the power supply unit, you could of also damaged the motherboard which can happen because this same thing happened to me. and the cpu may have been damaged. get back to me with more details of what i said above and are see what i can do for you. Thanks
Onlinepc-fix
lee
4/24/2008 8:47:36 PM •
Soltek...
Answered
on Apr 24, 2008
Soltek sl-k8av2-r motherboard
check your display card. it seems to be faulty.
If its onboard then use any PCI display card and try to boot. If its booting up then its confirm your onboard display got damaged.
Other than check settings in BIOS if there is any setting for VGA/VGA etc..
thanks
Iqbal
4/24/2008 6:31:36 PM •
Soltek...
Answered
on Apr 24, 2008
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
4/8/2008 5:12:14 PM •
Soltek...
Answered
on Apr 08, 2008
Sound drv
Manufaturers website.
4/6/2008 8:33:53 AM •
Soltek...
Answered
on Apr 06, 2008
Soltek motherboard without driver
Do you mean the AGP chipset driver?
you can get it at www.soltek.de
Unfortunately, the site seems to be under construction at the moment.
4/6/2008 7:40:14 AM •
Soltek...
Answered
on Apr 06, 2008
