20 Most Recent
Liebert UPStation GXT1000RT (GXT1000RT-120B) UPS System Questions & Answers
After battery replacement, upon power
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
9/9/2011 4:55:46 PM •
Liebert...
Answered
on Sep 09, 2011
Need to monitor status of Liebert 150 KVA UPS
Try to find your manual here in this site. Choose your Product Category, Product Application, Application Type and Specific Product. After that you can download the manual. Hope this helps. "http://www.liebert.com/servicesupport_pages/ProductDocumentSelector.asp"
3/9/2022 9:09:22 PM •
Liebert...
Answered
on Mar 09, 2022
Liebert gxt3 1500
staticbypass is actvated by the main control card via the press button swith,to transfter back to online mode its still the control card that do the timing for the transition to take place so i would suggest you test with another control card or try and be patient and see if it takes longer time to transfer back to online mode.
11/5/2015 12:15:13 PM •
Liebert...
Answered
on Nov 05, 2015
Battery over voltage
did you replace battery recently if yes,what is the ah of the new one you moved in,hope its the same ah with the one you moved out,if all batteries are new try to self drain batteries with battery tester and retest again with ups.
11/5/2015 11:45:53 AM •
Liebert...
Answered
on Nov 05, 2015
Liebert gxt2-10000rt208 fault indicator and A + E LEDs on. Did anyone know this alarm?
I'm going to go on a limb and say the unit also has the bypass indicator on as well, is that correct? A=On bypass due to overtemperature condition & E=On bypass due to inverter failure.
I can't see in the picture or hear it but is it beeping also? 1 second beep every 2 seconds? Thats on internal bypass. If none of this is true then you have a tricky problem.
1/10/2015 2:28:40 AM •
Liebert...
Answered
on Jan 10, 2015
