20 Most Recent
Sony Cyber-Shot DSC-WX5 Digital Camera Questions & Answers
Dsc wx5
Check your white balance and exposure compensation settings
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Problem connecting usb - no message appears
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Cant find my manual where
I don't believe this camera has a black&white mode. You can convert color photos to black and white using just about any photo editing program.
You can download the manual and the Cybershot handbook from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCWX5
Hi, when I click on the button to view pictures
Have you checked the batteries on the camera? Weak batteries will shut the camera off any time ther is a call for power that exceeds the charge left in the battery.If after you change or charge the battery and you are still having this issue let me know and we can go from there.
Please use Sony Cyber-shot batteries for DSC-H2 model camera
If your camera keeps shutting down and not allowing any pictures to be taken, use the 3 pixel setting. It may allow you to get at least some use out of the camera. After reading numerous reviews on this unit and comparing the performance of mine to that of a friend who also has it, I have to say that SONY made a slew of defective cameras and this should have been a recall. Some cameras seem to work fine, thus the good reviews. Others, and there are many many of these, shut down unexpectedly, won't work well on the 5 mega pixel setting, take terrible pictures (especially in low light) and generally aren't worth the money you paid for them.
What I soon learned was that it was running low on battery power and needed to be off most of the time or you would go through batteries like butter. Even when the camera is off and loaded with new cells it will quickly deplete itself. So you have to turn the thing off if you aren't about to shoot...this makes catching that special shot almost impossible, especially since when you do turn it on you then have to wait and wait and wait for the shutter to snap. Forget anything with low light
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
SONY DSC-S40 RESET IT SELF.
If you have already cleaned the lens gears and the issue persists, it is possible that the lens electric motor is not working properly. You can try resetting the camera to see if it helps. Here are the steps to reset the Sony DSC-S40:
- Turn off the camera and remove the batteries.
- Wait for a few minutes before reinserting the batteries.
- Turn on the camera and see if it works.
If the camera still does not work, it may be a hardware issue and you may need to take it to a professional repair service or contact Sony support for further assistance.
2/26/2023 2:52:49 PM •
Sony Cameras
Answered
on Feb 26, 2023
