20 Most Recent DR Scholl's Wood Exercise Shoes Shoes Questions & Answers
2answers
How do I adjust dr
There is a buckle that moves to the side. grasp it by the edges and move it back towards the edge. Once the buckle is clear of the pin, them adjust the upper to fit you and slide the buckle back over the pint.
7/27/2021 3:32:53 AM • DR Scholl's Wood... • Answered on Jul 27, 2021
I need new/replacement strap for DR Scholl's woodern sandals
you may get some joy by contacting the company directly.
11/4/2015 4:20:14 PM • DR Scholl's Wood... • Answered on Nov 04, 2015
How do you adjust buckles
It depends on the type you have. Some recent ones have a hinge agat the edge. If you have these, then lift up at the other edge and lift the strap and make it fit before shutting it again. If you have the type that slides, move it to the outside and lift up the strap.
4/11/2015 3:29:51 AM • DR Scholl's Wood... • Answered on Apr 11, 2015
The rubber soul on my Dr scholl exercise sandle is
I have replaced the sole on a number of my pairs with EVA, heel material for durability and TOPY. This is the best way to fix them.
3/31/2015 1:51:36 AM • DR Scholl's Wood... • Answered on Mar 31, 2015
Need Instructions for the Dr Scholls Thermal
Tho get the manual you will need to call Schering-Plough HealthCare Products Information Center at 1-866-360-3226, Monday through Friday, 8am - 5pm CST
Good Luck please rate 4 thumbs up and please leave a testimonial
4/3/2014 3:02:01 PM • DR Scholl's Wood... • Answered on Apr 03, 2014
The soles of all my dr scholl exercise sandals (wooden) have worn down to the wood. getting them repaired cost more than they cost new here in maui. is there any kind of quick fix, or not-so-quick, fo
I resoled mine this morning with some soling material that happened to be kicking around the house. They are expensive here and it is cheaper to resole. If it is expensive to resole there, why not send them off the island?
4/3/2014 2:44:55 PM • DR Scholl's Wood... • Answered on Apr 03, 2014
Need an Instructiion Manual for
type this into google i am sure you will get your answer
1/29/2011 9:26:17 PM • DR Scholl's Wood... • Answered on Jan 29, 2011
2answers
How to adjust a dr scholls
The Dr. Scholl sandal? Slide the metal band backward off the pin and then lift the strap off the pin and adjust to suit your foot.
7/27/2021 3:28:07 AM • DR Scholl's... • Answered on Jul 27, 2021
I'm not sure what the purchase MARCELINACP 4029357733 was for? Was it for some dr Scholl's sandals?
no it may be a scam its ove £120
1/13/2018 5:44:42 PM • DR Scholl's... • Answered on Jan 13, 2018
Raising a shoe by 3.5cms, by Scholl?
Sure. Send along the prescription and it can be done.
4/16/2015 5:20:53 PM • DR Scholl's... • Answered on Apr 16, 2015
Where can I get the official Dr Scholl's instructions for use of the Freeze Away wart remover?
I would check the Dr. Scholl web site. They will have them there.
3/14/2015 4:31:33 PM • DR Scholl's... • Answered on Mar 14, 2015
Oakley screw fell out
Here are a few steps you can take to address this issue: Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws. Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design. Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits. Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM • Clothing... • Answered on Apr 20, 2024
2answers
What do you pack in your purse?
Here are list of things you can carry in your purse: A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me. A pair of earrings / jewelry. Hair ties and bobby pins. A hair brush. A notebook / sketchbook. A pen and a pencil. Pack of tissues.
4/17/2024 7:09:47 AM • Clothing... • Answered on Apr 17, 2024
3answers
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM • Clothing... • Answered on Apr 17, 2024
I want to engrave my name on the back side of a necklace, how?
I suggest that you will get the necklace first and then take it to the jeweler for engraving.
4/7/2024 4:18:13 AM • Clothing... • Answered on Apr 07, 2024
2answers
What is a fascinator? So many people are talking about them on TV etc
A fascinator is a a headpiece that is a modern alternative to a hat. It's usually worn as a large, feathery decoration that is attached to a hairband or clip.
3/23/2024 2:56:59 AM • Clothing... • Answered on Mar 23, 2024
2answers
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding mirrawluxe_419039130_368272405952318_133677031493383980_n-1o5ccob0r24b1hj0bygsf3dd-d-0.jpg
3/8/2024 1:22:32 PM • Clothing... • Answered on Mar 08, 2024
Is there such a thing as a bridal fascinator?
Yes sure.Lots of brides now are using fascinators to accessorize their dresses in amodern way without looking like they are wearing a proper hat.
Try lookingat these sites to get some ideas:
http://www.weddingfascinators.co.uk/bridal-hair-accessories.html
2/25/2024 10:10:29 PM • Clothing... • Answered on Feb 25, 2024
I bought some rodenstock Wimbledon sunglasses
1/27/2024 9:29:12 AM • Clothing... • Answered on Jan 27, 2024
DR Scholl's Wood Exercise Shoes Shoes Logo
Popular Tags
10 questions posted
Top DR Scholl's Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a DR Scholl's Clothing Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • DR Scholl's Clothing Accessories
Most Popular Question
rubber soul dr scholl exercise sandle
  • Clothing Accessories
