20 Most Recent
Whirlpool WED7600XW Dryer Questions & Answers
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works.
Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary.
Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat.
Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction.
Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly.
Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition.
Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly.
Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues.
Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
Whirlpool duet model YWED9300VU0
Try kit 4392067. It's the 4 roller wheel kit with belt and pulley. I use them all the time on that model, but without the Y in the beginning. Not sure what the variation is there.
