20 Most Recent
LG WT5101H Top Load Washer Questions & Answers
My washer will not turn on
Power cut may have blown fuse . If not check mains filter. If that's ok then mother board may be damaged
Spin Cylcle Issue
sounds like it has bounced out of balance, it may have lost level, the springs in side might have lost some of there spring, or the clutch may be getting bad. the belt might be loose as well and starts slipping when going faster.
Spin Problem
THIS PROBLEM ARE YOU OCCURRING DAILY? IF IST DAILY ,,THE PROBLEM WITH INLETVALVE,,END OF THE CYCLE FROM THAT WATER LEAKING CONTINUOUSLY,,
My LG Washer Model #WT5101H,
I just fixed our WT5101H. It was not draining. The drain pipe, when held down to the ground, would flush out the water just fine, but when it was in the wall drain it did not register. Here's what I did:Took off the back panel. Located the drain pump and removed it from the base it sits on. I noticed right away than one of the connected wires was completely off. Maybe from the motion of the washer it had removed itself. We electrical taped the wiring to remain snug and presto... we have drainage working again. I took apart the drain pump to clean it out, and now we do have some leaking since I could not get the unit back together as complete and as sealed... might have to get some caulking or something to keep the little drips away.Sandi
