20 Most Recent
Pioneer VSX-1014 Receiver Questions & Answers
Connect an AUX cable
Use the speaker output and plug it into the mic socket. Not ideal but the alternative is to buy a cheap adaptor for the end of the aux cable so that you can plug your speaker output into the aux input.
HELP MY VSX 1015TX PIONEER
Try pressing the ENTER + VIDEO2 buttons on the front panel of the unit for 2 seconds. The unit should then come back to life and MCACC should go off.
No sound output from my pioneer vsx-1014k using
IOW, no audio from anywhere.
If it otherwise looks alive...
WARNING:
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
The power went out in
Yes, and it's quite easy. You need to locate on your receiver's front panel two buttons, labelled ENTER and VIDEO2 When the you press these two buttons together for a couple of seconds, the receiver should wake up. Please come back with a testimonial if helped :)
