20 Most Recent Canon PIXMA iP1000 Questions & Answers
Canon pixma ip1000 black ink stop printing suddenly
Hi, Based on your explanation I will try to help. Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
8/25/2017 5:45:30 AM • Canon PIXMA... • Answered on Aug 25, 2017
I have canon pixma ip1000.
This printer is quite old now and has a limited life on the print head. The fault you are describing sounds like blocked nozzles and can be as a result of either the print head starting to fail, or ink clogging the front of the nozzles. The most likely culprit will be the purge unit/capping station as it may have old ink and dirt/dust over time caked on it which could be making the problem worse by redepositing the junk into the nozzles instead of cleaning the head! I would suggest that if you are not too technical or hands on, then a new printer would be a better route to take as the cost of a print head is not worth the expense if cleaning the print head and purge unit with an old soft cloth and warm water doesn't help. I hope this info is useful.
4/6/2017 4:47:57 PM • Canon PIXMA... • Answered on Apr 06, 2017
Printing in one color only and only part of the picture
Have you printed a test pattern? Do you have ink in all the cartridges? If you have ink, you might just have a defective printer head if cleaning does not correct situation,.
10/25/2015 6:27:27 PM • Canon PIXMA... • Answered on Oct 25, 2015
Why does my Canon Pixma ip1000 not print black?
I think this is a pretty old printer. It would cost more to fix than a new one. I recommend you recycle it.
10/25/2015 6:05:41 AM • Canon PIXMA... • Answered on Oct 25, 2015
2answers
My printer misses lines when printing.
Definitely a partial clog. Remove your ink cartridge and take it to your microwave. DO NOT PUT IT IN THE MICROWAVE. Fold up some paper towels and apply enough water to the towels to get wet and damp but not dripping. Heat the wet towels in the microwave to get very hot (about 30 seconds). Now, place the cartridge on the steamy hot paper towel and let the steam and hot water dissolve the dried ink. After the towel cools drag the ink contacts across the wet paper towel and look for a smooth and even line of ink. One smooth wide line for black and three smooth lines for the color . Try the drag test on some dry paper towels for the final test. If necessary repeat the whole process again. For stubborn and very old cartridges let set on the wet towel for several hours and recheck. Good Luck.
1/9/2015 4:50:46 AM • Canon PIXMA... • Answered on Jan 09, 2015
My printer will not print in black
Try to find solution in Google
11/25/2014 10:46:25 PM • Canon PIXMA... • Answered on Nov 25, 2014
Printer will not print in black
Have you replaced the black ink cartridge? Have you tried the clean head utility? Find the printer in the Control Panel, right-click the printer, click Preferences. The Maintenance tab has a "Cleaning" button. Also look on youtube for head cleaning videos of the head; these are videos to be used with a head cleaning kit after removing the head from the printer.
11/23/2014 4:32:18 PM • Canon PIXMA... • Answered on Nov 23, 2014
How do you clean the printer head?
See this...
8/4/2014 4:04:47 PM • Canon PIXMA... • Answered on Aug 04, 2014
WHAT IS THE PROBLEM WHEN YOU RECEIVE AN ERROR OF UNABLE TO CONVERT POST SCRIPT FILE?
If this machine is running XP, or earlier (98, 2000, ME, etc.), beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you back up your data (pictures, documents, etc.) and get a newer machine, or don't try to get on the Internet with this one. If the machine won't boot or let you back it up, and you have important files on it, you could purchase a USB Hard Drive Adaptor, pull out the hard drive, and copy any important files to another machine. That way, at least you may not lose your files. Good luck.
8/4/2014 3:43:09 PM • Canon PIXMA... • Answered on Aug 04, 2014
Green, yellow, green yellow blinking lights
see on the canon site forum what blinking leds mean, then come here with explanation
4/7/2014 12:17:45 PM • Canon PIXMA... • Answered on Apr 07, 2014
My canon ip1000 printer show error "print head not available". but head already fix in place
The print head may not be proper electrical connection. Remove the print head and clean the electrical contacts on the ink cartridge and in the printer with methylated spirits, replace the print head and hopefully this will fix the problem.
2/2/2013 7:40:06 AM • Canon PIXMA... • Answered on Feb 02, 2013
I have a speaker it works but still the sound does
Check your sound settiong in control panel. Make sure that output sound isn't muted.
12/10/2012 6:59:41 AM • Canon PIXMA... • Answered on Dec 10, 2012
Canon pixma ip 1000 printer driver need to be down load
The following link should allow you to get whatever driver you require for this printer from the canon website by filling in your operating system:http://software.canon-europe.com/products/0010104.asp
9/9/2012 4:52:21 AM • Canon PIXMA... • Answered on Sep 09, 2012
Canon W6400 all the lighs are on but it does nothing
ck its settings
8/23/2012 1:19:23 PM • Canon PIXMA... • Answered on Aug 23, 2012
Everytime i load my black ink the warning is saying it not install properly
clean cartridge contact proper and install then check again if problem persist then change your cartridge with new cartridge
5/31/2012 2:03:04 AM • Canon PIXMA... • Answered on May 31, 2012
Computers & Internet Logo
79 questions posted
Top Canon Computers & Internet Experts
old marine
old marine
Steve Sweetleaf
Steve Sweetleaf
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Canon Computers & Internet
Most Popular Question
  • Computers & Internet
