20 Most Recent
Canon LASER SHOT LBP-1210 Questions & Answers
Canon lbp1210 service errroe how can solve it ?
The Canon Advanced Printing Technology has detected an
internal problem in the LBP-1210 Printer.
1) Turn off and unplug the printer.
2) Open the front cover and remove the Cartridge.
3) Reinsert the cartridge properly. Use both hands to close
the front cover completely.
4) Plug in and turn on your printer.
If the error persists, contact your Canon authorized
service representative
Steps to install
Insert the CD which came with the printer and follow the instructions
Canon lbp 1210
It means your printer needs a service due to ink leakage or some kind of internal damage.
Contact Cannon support to get the printer serviced.
Priting mistake
could be the problem of catridge show it to tech or service center
Printing mistake
It sounds like the print drum has become scratched, The only way to fix it is to replace the drum.
Service error
my printer show 'service error' and does not printing
Softwarezone.com
For what? Make ,Model of the Computer and the OS you are using.
I have no cd
Please visit the link belowhttp://www.canon-europe.com/Support/Consumer_Products/products/printers/Laser/Laser_Shot_LBP1210.aspx?type=download&page=1Remember to select your Operating system and preferred Language okay. Goodluck
Tengo una Copiadora Canon IR 1023, a cada rato se atasca el papel, se queda al pasar por el rodillo del termico no sale, se arruga y atasca.
Si tu copiadora Canon IR 1023 se atasca constantemente con papel y se arruga al pasar por el rodillo t?rmico, aqu? hay algunas soluciones y pasos que puedes intentar:
1. Verifica el tipo y la calidad del papel: Aseg?rate de utilizar papel de calidad y del tipo adecuado para tu copiadora Canon IR 1023. Utilizar papel de baja calidad, h?medo, arrugado o demasiado grueso puede causar atascos.
2. Limpia el rodillo t?rmico: Si el rodillo t?rmico est? sucio o presenta residuos de tinta o polvo, puede provocar atascos de papel. Apaga la copiadora, desench?fala y deja que el rodillo t?rmico se enfr?e por completo. Luego, utiliza un pa?o suave y limpio ligeramente humedecido con agua para limpiar cuidadosamente el rodillo t?rmico. Evita usar productos qu?micos agresivos o solventes, ya que pueden da?ar el rodillo.
3. Revisa las gu?as de papel: Aseg?rate de que las gu?as de papel est?n correctamente ajustadas seg?n el tama?o y la orientaci?n del papel. Las gu?as mal ajustadas pueden causar atascos y arrugas en el papel. Ajusta las gu?as cuidadosamente para que est?n en contacto suave pero firme con el papel.
4. Verifica y limpia los sensores de papel: Los sensores de papel son peque?os dispositivos que detectan la presencia y el movimiento del papel dentro de la copiadora. Si estos sensores est?n sucios o defectuosos, pueden causar atascos y otros problemas. Consulta el manual del usuario de tu copiadora para localizar los sensores de papel y c?mo limpiarlos adecuadamente.
5. Realiza un mantenimiento regular: Programa un mantenimiento regular con un t?cnico autorizado de Canon para verificar y limpiar los componentes internos de la copiadora. Un mantenimiento adecuado puede ayudar a prevenir atascos y otros problemas.
Si los problemas de atascos de papel persisten a pesar de seguir estos pasos, ser?a recomendable contactar a un t?cnico especializado de Canon o al servicio de atenci?n al cliente de Canon para obtener asistencia adicional. Ellos podr?n proporcionarte soluciones espec?ficas para tu modelo de copiadora Canon IR 1023 y brindarte un soporte m?s detallado.
