20 Most Recent
Tilia FoodSaver GameSaver Turbo White Questions & Answers
Gamesaver turbo will not seal
I had the same problem, the plastic nipple in mine was cracked, manufacturer defect and they don't make them anymore. Does anyone have a diagram of the inside of the food saver.
I have the foodsaver professional
Check the gasket. If it has any depressions in it it will not form i tight seal. I removed and flipped mine over and it now works great!
Foodsaver V3250 manual
Where can I get a manual for the FoodSaver V3250? Mine is new and it did not have one in it???
Thank You!
Sherri
Foodsaver v485 no longer seals
Hi tami prevostYour vacuum pump seals are wearing and not allowing the vacuum build up as it was new...Look at the manual that came with it and see it you can order parts for your vacuum foodsaver, if you can order the seals/orings,etc that is needed to repair the vacuum part of the machine.Please take time to rate meBud
