20 Most Recent
King Kutter ATV SeederSpreader 350Lb Capacity Model ATV () Questions & Answers
King Kutter 6ft tiller. It hit a metal fence post. The tiller will not turn, bogs down tractor. Where do I start?
You checked for a piece of post or rock stuck in the tines?You should be able to turn the PTO shaft by hand. Suggest you disconnect the PTO shaft from the tractor and make sure the problem is the tiller.The tiller end of the pto shaft has both a slip clutch and a shear pin to protect the gear box and tine shaft drive gear. See attachment.If you are unable to turn the PTO shaft by hand with it disconnected from the tractor then likely there is something jambed in the tines or internal damage to the gear box or tine shaft gear drive.Parts diagrams are in the owners manual. Manuals are free download at https://www.kingkutter.com/manuals
I have a King Kutter
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
The end of July we purchased a 4 foot tiller from
most warranty on tillers is 1 to 2 years depending on the brande, also it must be a MF defect. if the shaft broken for improper uses you may have a problem. warranty service centers well know what happened and how it broke. call your 800 number in your book also it gives you your warranty info there to.
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
Yesterday
