20 Most Recent
King Kutter Ii Gear Driven Rotary Tiller 4ft Questions & Answers
I have a Kubota B7510. Will a King Kutter II 48" tiller work on this tractor?
Susan Ensley supplies a great answer for this 2012 question!
I had that same problem with mine. What you have to do is to buy a longer shaft and cut it to the size that will work. Mine CAME too long for that purpose; cut it to fit my smaller Kubota. Traded that tractor in for a much larger one and had to repeat the process, only THIS one worked fine with the long length. I hope this makes sense! My female brain only knows how to explain it as I did! But, mine works now!
Oil leaks out of shaft
hello, you have a bad axle seal that needs replacing,replace or keep putting in gear oil,
The tiller will not rotate.
Sounds as if you might have destroyed the gearbox or cooked the internal clutches or both....nothing to do but disassemble the gearbox to find out...you may have a broken gear tooth or teeth jamming the pinion...the FIX may be more expensive than the cost of a new tiller...call Tractor Supply to see if replacement parts are even available...sorry to be the bearer of such bad news... ;-(
King Kutter 6ft tiller. It hit a metal fence post. The tiller will not turn, bogs down tractor. Where do I start?
You checked for a piece of post or rock stuck in the tines?You should be able to turn the PTO shaft by hand. Suggest you disconnect the PTO shaft from the tractor and make sure the problem is the tiller.The tiller end of the pto shaft has both a slip clutch and a shear pin to protect the gear box and tine shaft drive gear. See attachment.If you are unable to turn the PTO shaft by hand with it disconnected from the tractor then likely there is something jambed in the tines or internal damage to the gear box or tine shaft gear drive.Parts diagrams are in the owners manual. Manuals are free download at https://www.kingkutter.com/manuals
I have a King Kutter
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
