20 Most Recent Jado 807875194 Amadea Brushed NickelGold Roman Tub Faucet Questions & Answers
Why was my question deleted about Jado Classic Roman Tub faucet leaking badly?
Hello Vanessa I am here for about 10 to 12 hours a day and don't recognize the question. I answer most of them regarding plumbing. We do have a member who appears to delete questions to gain points. I have called him out, but nothing back from him. He has far too many points for the number of questions he has answered. I answer about 60 a day or more. Another issue is that we have an AI Answer Bot from India name Raja Akeem Akhter answering questions in a very vague and inaccurate manner, and I know the IT Department are deleting his answers. I hope they aren't deleting the questions rather than the answers! Very often the answer will be mentioned in the email you get from Fixya. Anyway sorry about that experience, let's try and fix the issue you have with your faucet. This is the page for all the parts schematics http://www.jadousa.com/techdocs.aspx?sw=classic%20roman So you are having issues removing the decorative cover that hides the cartridge top? There is a trick. Take one of the thin plastic bags that your fresh produce comes in from the supermarket and make a hole in the bottom. Feed or over the handle and slide it down to the bottom of the fitting. Tape around the bottom and squirt a liberal amount of WD40 down into the bag. It will penetrate up into the threads. Over the space of 24 hours give it another couple of shots of WD40. Then remove the bag. Clean the bell and put 3 wraps of duct tape about the bell. Then you can use Channel Lock Pliers to apply pressure and remove the cover. https://www.google.com/search?q=Jado+Classic+roman+tub+replace+cartridge They all have model numbers https://www.google.com/search?q=Jado+Classic+roman+tub ..
4/30/2023 10:48:41 PM • Jado Plumbing • Answered on Apr 30, 2023
I have a Jado glance faucet. I removed it from the sink to replace the cartridge but I cannot get to the inside of the faucet. How do I open it?
After removing the set screw near the bottom of the body (#12 in parts diagram), turn the faucet over and tap the body (the bottom of the shiny body where it contacts the countertop) with a hammer while holding onto the hoses, the body will slide off, so don't let it drop.
5/21/2020 1:23:33 AM • Jado Plumbing • Answered on May 21, 2020
I have a 20+ year old Jado bathroom faucet. My plumber could not get it apart and suggested I cut it out and get new one. Can you suggest a plumber with experience like this who knows Jado?
If he knew how to disassemble the faucet but it was corroded so badly it would not come apart<?>... sometimes a Dremel with cutting wheel is the only option. If he wasn't familiar with "JADO"... ask JADO to help identify your faucet. http://www.jadousa.com/default.aspx?aspxerrorpath=/searchResults.aspx Get the technical documents yourself and then find a different plumber.
3/9/2019 11:11:32 PM • Jado Plumbing • Answered on Mar 09, 2019
Trying to remove Jade hot water faucet to replace cartridge. Scutcheon seems to be stuck to Ltd cartridge and won't budge. Any suggestions?
vinegar and old toothbrush to work it in the threads. let sit for a few minutes. repeat. keep trying gently. try tightening it a TINY bit before unscrewing. vise-grips with rag wrapped around.
1/16/2018 8:51:47 PM • Jado Plumbing • Answered on Jan 16, 2018
I have a JADO Oriental faucet with separately installed knob handles. No set screw. How do I go about removing them?
Use a block of wood and a couple flat head screwdrivers carefully pry up on the faucet handles using the wood as leverage. But do not force them, heat up with a hair drier first before removing.
1/14/2018 12:57:45 AM • Jado Plumbing • Answered on Jan 14, 2018
Can't loosed fixture of Jado filtered water faucet like reverse osmosis tap. Could threads be reversed? Suggestions how to loosen? Need to replace washer.
It will require two people one to hold from top and underneath using deep socket remove nut.
11/21/2017 8:02:33 PM • Jado Plumbing • Answered on Nov 21, 2017
Is the cartridge in a jado new haven faucet 1 piece
cartridges are one piece unless cartridges replace the insert and tap washer
10/29/2016 10:46:42 PM • Jado Plumbing • Answered on Oct 29, 2016
How to remove jado faucet handle?
Is it a star socket maybe?
9/28/2016 10:21:47 PM • Jado Plumbing • Answered on Sep 28, 2016
Will replacing a cartridge in my Jado Glance single lever bathroom faucet make the water flow again? It&#39;s down to a trickle!
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
12/26/2014 4:34:55 PM • Jado Plumbing • Answered on Dec 26, 2014
I have a Jado faucet
Please find your faucet on the link below or close to your faucet. That way I may help you fix the problem. I am a general contractor and know all faucets on the market. I just need to know the model # to help you more.
http://www.jadousa.com/searchResults.aspx?d=1&t=36
6/8/2011 2:15:50 AM • Jado Plumbing • Answered on Jun 08, 2011
I have a Jado Glance
sounds like the o-rings inside the valve cartridge are bad. turn off valves and remove the cartridge and take it to your local hardware store or plumbing repair shop to match up and buy a new one.
this should solve your problem.
if you have further questions about this problem ,, please feel free to ask.
c...
1/30/2011 4:22:04 AM • Jado Plumbing • Answered on Jan 30, 2011
We live in an apartment
the washer/and or seats are not properly set and as water rushes in its forcing its way thru seat washers and creating whistling noise
11/22/2010 1:32:23 AM • Jado Plumbing • Answered on Nov 22, 2010
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
Jado 807875194 Amadea Brushed NickelGold Roman Tub Faucet Logo
Popular Tags
1 questions posted
Top Jado Plumbing Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Jado Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Jado Plumbing
  • Jado Plumbing
Most Popular Question
question about jado classic roman tub
  • Plumbing
