20 Most Recent Tally T6218 Matrix Printer Questions & Answers
Showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
3/17/2018 12:16:04 PM • Tally T6218... • Answered on Mar 17, 2018
3answers
Problem for lipi 6312 tally genicom line printer
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
3/18/2016 3:35:21 PM • Tally T6218... • Answered on Mar 18, 2016
Tally t6218 prints and stops with no errors
The power supplies are known for shutting the printer down without any error if that is the symptom, replace the power supply. TALLYGEN 084435 POWER SUPPLY ASSY T6218 Refurbished If not let me know exactly what it is doing.
12/28/2015 2:55:28 PM • Tally T6218... • Answered on Dec 28, 2015
Why does it work for about 10-15 minutes, then stop and indicate ERROR HAMMER VOLTAGE 1?
Usually that is something wrong with the hammer bank MRP provides IT Parts Product Supplies and Services In rare instances it can be cabling, power distribution PCB or the main logic.
7/17/2015 7:06:15 PM • Tally T6218... • Answered on Jul 17, 2015
2answers
Am using a tallygenicom 6306 and keeps on bringing...
please follow these notes to calibrate the paper out sensor.
1/6/2015 8:07:47 AM • Tally T6218... • Answered on Jan 06, 2015
0answers
0answers
Tally t6218
Be the first to answer 1/9/2014 1:13:07 PM • Tally T6218... • Posted on Jan 09, 2014Be the first to answer
2answers
TALLY 7.2 BACKUP IN pc PLEASE HELP ME HOW TO STORE
can u sent me the backup i can solve the problem.. Tally velu - sree sai solutions 9789495543
10/18/2013 4:34:50 PM • Tally T6218... • Answered on Oct 18, 2013
CONFIG 1*
If the printer is showing "CONFIG 1*" this is not an error, this message is simply advising that Menu CONFIGuration 1 is selected hence the * beside the message.Assuming the settings in CONFIG Menu 1 are correct if you send data to the printer in the correct format it should print.
5/22/2013 11:52:38 PM • Tally T6218... • Answered on May 22, 2013
All my tractors are okay
you need to clean paper motion sensor first,check its connection on logic board clean the connector of sensor,if you can then please post u r problems with printer model then i can explain it more.
6/5/2012 10:58:01 AM • Tally T6218... • Answered on Jun 05, 2012
My tally t6218 is giving
you need to check logic board.
6/5/2012 7:54:19 AM • Tally T6218... • Answered on Jun 05, 2012
Error message PAPER OUT and PLATEN CAL required
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
1/11/2012 2:08:51 AM • Tally T6218... • Answered on Jan 11, 2012
Printer Tally t6200 series is
check the logic board if not one of the coils is faulty
10/18/2011 11:59:28 AM • Tally T6218... • Answered on Oct 18, 2011
3answers
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.gp+3ytmzowxemaaaaaelftksuqmccxotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=ak0nfwmwb8waaaaasuvork5cyii=
10/15/2011 10:09:15 PM • Tally T6218... • Answered on Oct 15, 2011
Tally T6218 Matrix Printer Logo
100 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
tally printer error some times hammer
  • Office Equipment & Supplies
