20 Most Recent
Tally Line Matrix T6050 Printer Questions & Answers
DISPLAY SETTING T6050 PRINTER
I'm not 100% sure what you are asking here, but on that printer to navigate the menus is a bit odd. Scroll to the option you want and press the key with the '1' on it then scroll to your next option and press the key with the '2'. The next menu option uses the '3' and finally you would use the enter key to display the value for the option that you navigated to using the '1,2,3' keys.
T6050 Printer not booting
there may be two problems in the logic card of the printer
1 .ONE OR MORE RESISTANCES R165 , R166 , R167 , R170 , R171 MAY BE DEFECTIVE..
2 . FIRMWARE MAY BE CORRUPTED , RELOAD IT.
T6050 self testing
If u r a repair technician here are some useful steps
1. check rp1 to rp13 resistance pack ( 47 ohm and 33 ohms )
2. download firmware
3. touchup the flash and font rom (U33 , U34)
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
- Connect the printer to pc through parallel port.
- Press "FF + ^ + CONFIG" at the control panel and power on the printer .
- Panel will show "ready to download".
- In dos mode type "vdv3000r -pb" and enter .
- After completing the firmware loading printer may show NVRAM fault.
- Press "CLEAR"and printer will restart to finish.
6050 belt slips continously
replace the shuttle belt or fix insulation tape on the pulley of both shuttle motor and shuttle wheel and then refix the belt.
Power board
the problem is not mentioned exactly . By the way you can check the out put voltage +48 v DC at the output cable which is connected to logic board . If it is not there , check fuse 3.15 AMP , thermistor , IRF 840 , if u r technical and knows how to repair .
