20 Most Recent
Duo Fast Duofast Carpet Pro Electric Staple Gun Wcase Questions & Answers
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Duo-fast electric tacker stopped working
kathleen lay the tacker on its side ,head to the left ,take out 4 screws remove cover ,there is a thermo fuse lower right .you can test it with an ohm meter . most likely the problem,if not welcome to the duofast demon within. iv\'e had my tackers for over 30 yrs you need 3or 4 of them to keep one operating. also finding parts for older ones is proving to be differcult. i think they want us to buy the new ones. hope it helped jimmy c
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
