20 Most Recent
Hitachi CP-X1200 Multimedia Projector Questions & Answers
How do I clean the filter of the Hitachi CP-X1200
Remove and use fine bristle brushes assisted with a jet of air which will clean up the fine netting of the filter. It is important that the filters are occassionally cleaned so that there is no dirt accumulation within the lens unit that can reduce the life of the LAMP and save an expensive repair.
Is the only difference between at CP-X1200 and
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Upside down image
With the MAIN menu, Select a mirror status using the "up" or "down" arrow. NORMAL H:INVERT V:INVERT H&V:INVERT
Can i hook up a macbook to this projector?
sure can!
There are a few options. Check out the apple website for a list of adapters.
Your best bet, depending on what macbook you have, would be a mini-DVI (plugs in to your macbook) to a DVI (plugs into the projector computer input)
The adapters are quite cheap at around $15 adn this will make the projector work just like an extra monitor connected to your macbook
Good luck!!
Can't reset lamp timer
Turn on the projector, and reset the lamp timer.
(1) While the projector running, press the MENU button to open the menu.
(2) Choose the “OPTION” on the menu using the / button, then press the
button or ENTER button.
(3) Choose the “LAMP TIME” using the / button, then press and hold the
RESET button for 3 seconds.
(4) Choose the “RESET” using the button.
memo When the lamp has been replaced after
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
- Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
- Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
- Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly
As a first step, remove the filter (s) and clean them well or replace them with new filters.
It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt
I hope you can make your Hitachi work properly
Regards Franco Dosil
Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente
Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos
Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad
espero Puedas hacer funcionar correctamente tu Hitachi
Saludos Franco Dosil
Hi, my Hitachi CP-X445 projector will not stay running for more than 5 minutes when mounted feet up, but there is no problem running feet down, any ideas?shuts down on high temp
Thanks, Jose
the lamp is not good
you need a Original lamp
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
Hope to cooperate with you.
Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps
www.Lampdeng.com
I have a yellow spot on my Hitachi cpx10000 projector.
the Lcd panels are fault
or
the polarizer isfault
www.Lampdeng.com
What could have happened to the projector to get a large blob that changes shape and is purple colored. Like an amoeba that grows and moves around.
Font strokes are not cleaned
Black silk font is not black enough
reason:
WhatsApp ID:+8613178867858
Skype:
[email protected]
Wechat ID:+8613178867858
Email:
[email protected]
Email:
[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
My hitachi A120n projector has no power light checked internal fuse and ok .
The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Hitachi projector cp-wx3041wn problem Power & temp light on ? How to solve
You should clear the air filter
and reset the air filter timer and the lamp timer
menu-advance-option-reset the air filter
menu-advance-option-reset the lamp filter
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Posted on May 31, 2019
Hitachi cp-rx60 not powering Temp led light blinking red non stop what could be the problem
you should clear the air filter
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
