20 Most Recent
Hitachi CP-X328 Multimedia Projector Questions & Answers
The projector was used last
Is the bulb any good? If it has filament it can be tested with ohm meter. If no filament there will be a high energy ballast that feeds the bulb - that could be the culprit also.
Casting a blue tint
This could be for a variety of reasons.
First, check all your connections to make sure everything is connected properly and undamaged. If you are using a VGA cable/computer cable, make sure the pins are not bent.
Next, check the cables themselves. I do this by flexing the cable back and forth, starting at one end and working my way to the other. Go slowly and make sure to do this every few inches. If there is a damaged wire, this will cause the image on the screen to flicker or change color. Any damaged cables found should be replaced.
If this does not work, try removing individual cables and using a different one. Do this one cable at a time in order to try and identify where the problem might be. This is assuming you have spare cabling.
If everything is connected properly and nothing appears to be damaged, go into the projector menu and check all your color settings. You'll see you have a variety of options. If these are set to default and you still have discoloration, the problem is most likely internal and may require a technician.
One additional option is to check the data source to make sure all the settings on that are correct as well.
Which lamp i need for replacement. for Hitachi
Hello :
I recommend you to contact the manufacturer or the Hitachi local dealer for more information .
For more information about your product , you can check the manual
here .
PLEASE DON'T FORGET TO RATE .
good luck .
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
- Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
- Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
- Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly
As a first step, remove the filter (s) and clean them well or replace them with new filters.
It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt
I hope you can make your Hitachi work properly
Regards Franco Dosil
Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente
Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos
Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad
espero Puedas hacer funcionar correctamente tu Hitachi
Saludos Franco Dosil
