20 Most Recent Rancilio Classe 6 E 2 gr Espresso Machine Questions & Answers
The water pressure is on 6 all the time, if I turn the nut on the pumps head it does not make any difference. Any idea? Thank you.
That might be the reading for the inlet water pressure, it should go the 9 bar when the pump is activated.
4/5/2014 1:38:25 PM • Rancilio Classe... • Answered on Apr 05, 2014
2answers
I have no water pouring out of the portafilter.
Lets see if we are on the same page here, without the portafilters in place no water flows out of the groupheads, correct. Ok, first I would check the pump gauge to make sure it was going to 9bars when the pump is running. Then I would remove the front panel and check the solenoids on the group that is not working to make sure the coil works. Run the head for a few seconds and then stop if water drains out the bottom of solenoid, we can move on, if not turn machine off and let it cool down, turn off water supply. Then remove black coil, by removing the discharge tube then 14mm nut. Next loosen silver tube nut and remove. Do Not Remove The Allen Wrench Screws. Now Turn on the water quickly to see if water flows from middle of square brass fitting. If not use a paper clip to clear and try again by opening the water quickly and closing it. If water flows use an ohms meter to check the coil. If the coil is fine then the problem is higher in the machine you will have to remove the top panel. The machine is blocked at the metering jet, possible because one side is not being used as often or a new filter was installed without being flushed. The metering jet is on one of the big nuts on the top of the group.
11/24/2012 5:55:08 PM • Rancilio Classe... • Answered on Nov 24, 2012
0answers
How do I change the
You will have to adjust the pump. there is an adjustment nut on the side of the pumphead, if you screw it in that gives you more pressure, and if you loosen less.
9/30/2011 11:02:57 PM • Rancilio Classe... • Answered on Sep 30, 2011
Tengo un problema con la
my spanish is not good but i think you have a the hot water solonoid valve is stuck open or has a piece of scale keeping it from sealing,if it is a manual valve the plunger gasket or valve seat needs to be replaced.
9/16/2011 9:31:42 PM • Rancilio Classe... • Answered on Sep 16, 2011
Water keeps coming into the
First thing check the manual fill under drain tray to make sure it is in the off position, next check the water level in the sight glass, I will assume the machine has a level probe connected to the boiler and not the level card on the sight glass. Next check the inlet valve. If water comes into the boiler without stopping when the machine is turn on and it overfills then the connection on the level probe is missing or the inlet solenoid is not closing and needs to be checked for blockage.
8/15/2011 9:28:31 PM • Rancilio Classe... • Answered on Aug 15, 2011
Hi We have a Rancilio
No, the inverter is designed to compensate the battery voltage drop . Most likely the unit has a bad connection, either at the heater (or its thermostat) or at the pressure pump.
You will have to open it and check the electrical connectors and the status of the pump.
8/13/2011 5:54:48 AM • Rancilio Classe... • Answered on Aug 13, 2011
I have bought Rancilio model:
It should be single phase but it can be converted to 3 phase power. Max power will consumption will depend on the size of the element that is installed. I do not know if you have a 6300w or a 5000w element. There is a face plate on the front with the power consumption.
1/24/2011 4:09:27 PM • Rancilio Classe... • Answered on Jan 24, 2011
Rancilio epoca 2 head machine. Lights are flashing
Machine is not heating, the lights should flash until it heats up to 1.2 bar on the top gauge. If not check the water level in the machine and check the red reset switch to see if the thermostat tripped.
7/2/2010 9:43:50 PM • Rancilio Classe... • Answered on Jul 02, 2010
Problems with water flowing out of the shower heads
Check the diffuser and screen, try swapping them around to make sure that is the problem. If that is not he problem then the tubes from the exchangers need to be descaled.
7/2/2010 9:32:40 PM • Rancilio Classe... • Answered on Jul 02, 2010
Do you have a manual on how to use the machine
www.espressotec.com/store/pc/Rancilio-Baskets-c119.htm - Canada -
try this link it should help
good luck
5/15/2010 11:21:56 AM • Rancilio Classe... • Answered on May 15, 2010
Rancilio Class 10 Espresso Machine. It is not reaching the right pressure, the water comes hot but there is not enough pressure for preparing an espresso. What could be the failure, the pump?
Question edited for clarity. Service manual in the link. Test water temperature and pump pressure. These machines need servicing every 6 to 12 months depending on use. https://www.google.com/search?q=rancilio+class+10+espresso+machine+service+manual ..
4/14/2024 6:04:30 PM • Rancilio Coffee... • Answered on Apr 14, 2024
I need more temperature from my espresso machine
Often these temperature differences are solved by descaling. Do never use vinegar. One can buy citric acid crystals or powder (not the same as lemon juice) and dissolve that chemical in water. I buy it in the Chinese Mall. Do not make a too strong acid. Shops sell maintenance powder which is the same but that is quite expensive. Let the acidic water go in and through the coffee maker until it looks clear. Next rinse with water for quite a number of runs. You may see how strong the citric acid that you make is by descaling something else and wait for about an hour. Another acid to be used in coffee makers is lactic acid. Lactic acid is bought as a cleaning agent. Also very strong and to be diluted with water.
12/10/2023 12:15:56 PM • Rancilio Coffee... • Answered on Dec 10, 2023
Rancilio Two-Group Automatic Classe 10 Espresso Machine. No software error message?
Question edited for a lot more clarity. Did you try a Power Reset so that the internal software operating system reloads? Pull the mains plug. Wait 10 minutes. Press and hold the Power button for 2 minutes to dissipate main board power. Plug back in and turn on. If that doesn't work, phone them up. https://www.google.com/search?q=rancilio+classe+10+no+software https://www.manuals.ca/rancilio/classe-10-sde/manual?p=128 ..
8/17/2023 4:34:45 PM • Rancilio Coffee... • Answered on Aug 17, 2023
Rancilio Classe 6 E 2 gr Espresso Machine Logo
21 questions posted
Top Rancilio Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Rancilio Coffee Makers & Espresso...
  • Rancilio Coffee Makers & Espresso...
Most Popular Question
no water pouring out portafilter
  • Coffee Makers & Espresso Machines
