20 Most Recent
Rancilio Epoca ST-1 Espresso Machine Questions & Answers
My Rancilio Epoca ST1 would not turn on yesterday
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
I switched on my Rancilio
If it is a 110 machine it is most likely single phase, most equipment in the US(assuming you are in the US is wired single phase). If you turned it off seconds after you realized it was not connected to water you will be fine, there would be no damage to the pump. Just connect the water then turn on the first switch only when the boiler fills tunr on the middle switch.
RANCILIO TWO HEAD COFFEEE MACHINE
Hello nsplumbing,
I understand that you are having a problem with your Rancilio two head coffee machine. However, to help you we need to know the model of machine that you have so that we may be able to look up the service manual as Rancilio make more that one double machine. You should be able to locate the model on the rear of the machine.
Thank you for helping us help you.
Justin
I am using a two
Hold down right most button for 8 - 10 seconds, then press button to program when you get your volume press button to stop repeat for next buttons, when done press stop button to get out of program mode.
