20 Most Recent HEALTHRIDER H55t Treadmill with Doorway Delivery - - Questions & Answers
Healthrider H55t makes a clicking noise
Check the front roller. Remove the drive belt and run the motor. If the noise is not there replace front roller.
1/4/2014 4:34:05 AM • HEALTHRIDER H55t... • Answered on Jan 04, 2014
HEALTHRIDER H95T Treadmill blue motor wire replacement
If the blue wire from the motor on your HEALTHRIDER H95T treadmill has broken at the metal connector and it's not listed as a part, you can try the following steps:
  1. Contact the manufacturer: Reach out to the manufacturer of the treadmill to inquire about replacement parts or repair services. They may be able to provide you with a replacement wire setup or direct you to a service center that can help.
  2. Find a similar connector: If you are unable to find a replacement wire setup from the manufacturer, you can try to find a similar connector at a local electronics store. Take a picture of the broken connector and bring it with you to help you find a matching one.
  3. Repair the wire: If you are unable to find a replacement connector, you can try to repair the wire yourself. Use wire strippers to remove the broken wire from the connector and strip the end of the wire that is still attached. Then, use a wire splice connector to join the two wires together. Be sure to use a crimping tool to ensure a secure connection.
  4. Seek professional help: If you are not comfortable repairing the wire yourself or are unable to find a replacement part, consider seeking the help of a professional. A qualified technician may be able to repair the wire or suggest an alternative solution.
It is important to ensure that any repairs or replacements are done safely and correctly to avoid injury or damage to the treadmill.
3/8/2023 7:42:38 AM • HEALTHRIDER... • Answered on Mar 08, 2023
HealthRider S500xi doesn't incline, slow down or stop with button
I hope you will get an answer soon. You can buy Provigil to reduce extreme daytime sleepiness. It also helps to bring alertness to your body.
11/8/2021 4:23:47 AM • HEALTHRIDER... • Answered on Nov 08, 2021
Do you sell manuals for healthrider S400?
We do not sell anything. Google the manual, they are free.
10/26/2021 9:06:00 PM • HEALTHRIDER... • Answered on Oct 26, 2021
Model h90t. Why can't it be turned on again?
We need more information on how and what up date you were doing and how it was being done. If this was a firmware update and it was interrupted, you may have a problem that requires the removal of the main board and having to send that board into the manufacturer to have it "reflashed."
4/29/2021 7:00:06 PM • HEALTHRIDER... • Answered on Apr 29, 2021
Healthrider H90t use the machine regularly, it isn't more than a few years old. The belt has stopped working, all control panel works. Suggestions please.
Manual below It talks of lubricating the belt and belt adjustment. It has a troubleshooting section https://www.manualslib.com/manual/694466/Healthrider-H90t.html?page=1#manual It also talks of a circuit breaker switch but I would think you would have no power if it tripped.
4/6/2020 2:29:11 AM • HEALTHRIDER... • Answered on Apr 06, 2020
My Healthrider 600i works fine except for the
You have to replace the entire console.
1/20/2018 5:11:15 AM • HEALTHRIDER... • Answered on Jan 20, 2018
I have HealthRider model HRTL71830. Was using it
Unfortunately, you need to replace the entire console. HealthRider's consoles are notorious for this behavior. The company that manufactures them only sells the console as a whole unit so you can get individual parts. Depending on the age of the machine you'll be looking at between $300-$800.
6/18/2017 2:55:36 PM • HEALTHRIDER... • Answered on Jun 18, 2017
Healthrider s 500i won't turn. Haven't used for a long time but has alway turned on.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
12/6/2016 4:25:46 PM • HEALTHRIDER... • Answered on Dec 06, 2016
I own an older model Healthrider treadmill (12 years or more). Lights show power but er show on and belt won't move.
If you wish to get some details About treadmill error codes; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
11/26/2016 1:41:30 PM • HEALTHRIDER... • Answered on Nov 26, 2016
HEALTHRIDER H55t Treadmill with Doorway Delivery - - Logo
Popular Tags
2 questions posted
Top HEALTHRIDER Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • HEALTHRIDER Exercise & Fitness
Most Popular Question
healthrider h55t makes clicking noise
  • Exercise & Fitness
