20 Most Recent HEALTHRIDER S300i Treadmill Motor Control Board 14470 Questions & Answers
You need to replaced the walking belt and have a professional reset the drive belt to the proper tension.
HEALTHRIDER... | Answered on Aug 02, 2017
DEAR IF YOUR TREADMILL IS OLD AND YOUR WEIGHT IS MORE THAN 80 YOUR MOTOR TREADMILL IS WEAK NOW AND MUST BE REPLACE IT ONLY .
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
HEALTHRIDER... | Answered on Apr 18, 2017
If it was outside, was it under cover? If it was not, then the console circuitry are corroded and not fully up to themselves. If it was under cover, same thing can happen. temperature and humidity, moisture and cold can also impair the performance of the unit. It may be a difficult problem to trace unless you can open the console and see for yourself the state of the printed circuit board/s. If it looks like silvery powder around the IC's (integrated circuits) pins, then tht's some air and moisture damage. If you live by the sea, same thing will happen on appliances left outside. And to find the cable chewed, looks like it's been outside for a long time and may definitely have rust on the circuit board, in other words - moisture damaged. If there is no silver rust (powdered ash-type rust) and the printed circuit board looks clean, then try and locate the treadmill manufacturer or its supplier websites and email them the problem you're having.
HEALTHRIDER... | Answered on Aug 01, 2014
please see the video and proceed according. God bless you
HEALTHRIDER... | Answered on Nov 28, 2013
the voltage controller is the same for input voltage terminal of the motor .
test the input voltage terminal motor, if there ARE not the motor is faulty.Read my personal TIPS motor
2) test the output voltage control board, if there ARE not the control board is faulty
God bless you
HEALTHRIDER... | Answered on Oct 22, 2013
1) test the voltage input motor, if there are voltage the motor NEED repair
2) test the output voltage board, for input voltage motor, if there are NOT voltage , the board is faulty.
see my personal TIPS, very important.
God bless you
HEALTHRIDER... | Answered on Oct 17, 2012
for waht reason do you need clear the memory? in treadmills. Normally you do not need to do that. Please what is the reason, and will reply .
God bless you
HEALTHRIDER... | Answered on Jul 17, 2012
Call Treadmill Doctor at 800-750-4766 and they will walk you thru the steps needed to clear the board
HEALTHRIDER... | Answered on Jul 16, 2012
1)see if the breaker is tripped
2) tight the flexible cord from keypanel vs display board
3)tight the connector display board vs lower board
4)see the main motor board is working if the signal is coming by 5vdc
5) main motor faulty repair.
see block diagram
HEALTHRIDER... | Answered on Dec 13, 2011
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
HEALTHRIDER S300i Treadmill Motor Control Board  14470 Logo
42 questions posted
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
Treadmill Repairs...
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • HEALTHRIDER Exercise & Fitness
Most Popular Question
39 t fold treadmill
  • Exercise & Fitness
