20 Most Recent
Haier HWR06XC7 Air Conditioner Questions & Answers
My air conditioner want turn on or anthing and it
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Fan will not run without starting it yourself and will not run high speed at all
Sounds like an old unit with a bad run capacitor or
check the components on the board for burnt wiring.
Fans on window units are controlled by a 3way switch. High, Med., and low. Your power and in most cases a capacitor which doubles for the compressor and fan.
So it can only be 1 of the 3
Burnt out windings on the motor
Bad switch
Bad capacitor
E1 error code
E1-Automatic filter clean
reminder.
Turn the air conditioner OFF and
unplug it. NOTE: The air conditioner must be unplugged for the automatic
filter clean timer to reset.
Clean the filter. See the Care
and Cleaning section in your use&care manual. After cleaning, replace the filter and plug
the air conditioner back in.
My Haier window ac unit is dripping a lot of water
The window unit is most likely not tilted towards the outside so that the condensate (water) can flow to the drains on the outside part of the unit. Try leveling the A/C or even tilting (Slightly) towards the outside. This will cure your problem.
If this does not cure the problem then you will have to remove the a/c from the window/wall and remove the cover. Inside you will see the drip pan in the bottom and will have to clean the water channels the run from the pan to the outside part of the unit, they will be clogged with dirt or debris and not letting the water flow properly.
Hope this helps.
E1 ERROR ON HAIER AIR
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
