20 Most Recent Xante Accel-a-Writer Laser Printer Questions & Answers
0answers
0answers
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand. thanks
8/18/2016 7:46:29 PM • Xante... • Answered on Aug 18, 2016
Accel-a-Writer 3G 64bit
Solution for Windows is here XANTE 3G 32 64 Universal Driver zip
3/13/2014 11:38:37 AM • Xante... • Answered on Mar 13, 2014
0answers
Paperproblems
Be the first to answer 2/19/2014 3:30:45 AM • Xante... • Posted on Feb 19, 2014Be the first to answer
Essaysit?
Yeah i think this is the possible question and answering about the recommendation. For me, i would certainly saying about the smart custom writing. After all you know they deserved it, deserved for their true and legal service and marvelous essayist working with them. What do you say about the smart custom writing? http://www.smartcustomwriting.com/best-essays
12/14/2013 12:20:47 PM • Xante... • Answered on Dec 14, 2013
0answers
0answers
0answers
3answers
Shows a paper jam but
First to correct the paper feed problem:
Take the tray out and clean the roller on the traand the seperation pad (also on the tray) with a damp cloth with a dab of dish detergent. The clean the paper pick up roller in the cavity abover where the paper tray fits in.
Then reset the printer:
  • Turn off the printer for 30 minutes and restart.
  • If not corrected - reset the printer by holding ONLINE and TRAY SELECT keys in the front panel during startup (when the black bars start across the screen on Series 4). It should display RESET if done properly.
  • Afterwards , try to print a configuration page from the menu.
    Let me know.....
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    1/5/2011 8:24:12 PM • Xante... • Answered on Jan 05, 2011
    Where are the paper jam sensors ???
    you can locate them in the picture beneath
    12/29/2010 7:46:23 PM • Xante... • Answered on Dec 29, 2010
    2answers
    Is there a driver for Windows 7 for Xanta 3G
    check it at Xanta accel a writer 3G lasr Print homepage
    12/3/2010 4:25:28 AM • Xante... • Answered on Dec 03, 2010
    Says ready to print but does not print. Have
    Check the cartridges to see if they are properly in place, check the papers to see if they need to be push further in the paper tray.Usually those are common problems, there are other things you can do such as clean the print drum, to clean the print drum you need to follow these steps: Open the printer and remove the toner cartridge.Inspect the drum for sign of damage,if it is damage you should replace it.Remove any large spots of toner with a tweezer or pliers,pay close attention while doing this because you need to avoid scratching the surface of the drum.Dip a cotton swap into rubbing alcohol and gently swipe any visible soil on the drum.If the entire drum is dirty put a few drops of alcohol on a lint free cloth and carefully wipe the drum. If you notice dirt anywhere else you should clean it while the cartridge is still out.Reinstall the cartridge and print a few test pages to see if the problem is solve,if the problem still exist you should replace the drum.
    8/30/2010 9:28:50 PM • Xante... • Answered on Aug 30, 2010
    0answers
    FUSER UNIT REQ
    Be the first to answer 8/3/2010 10:26:48 AM • Xante... • Posted on Aug 03, 2010Be the first to answer
    Xante Accel-a-Writer Laser Printer Logo
    38 questions posted
    Top Xante Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    ADMIN Andrew
    ADMIN Andrew
    David Kassin
    David Kassin
    Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    • Xante Office Equipment & Supplies
    Most Popular Question
    i need a new toner cartridge for my
    • Office Equipment & Supplies
