20 Most Recent LG SteamWasher WM2801H Front Load Questions & Answers
look for a blown fuse in panel or a bad door switch
LG SteamWasher... | Answered on Jun 08, 2015
it could be in your hose
LG SteamWasher... | Answered on Dec 17, 2010
One of the water inlet valves is not closing all the way. I will bet that you live in an area with hard water. The valve likely has a lot of buildup on it, and just can't close all the way now. You might be able to remvove the valve and soak in vinegar before buying a replacement valve.
LG SteamWasher... | Answered on Nov 02, 2009
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG WM Washing... | Answered on Oct 29, 2018
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
LG WM Washing... | Answered on Dec 27, 2017
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
LG WM Washing... | Answered on Apr 25, 2017
http://www.lg.com/au/support/support-product/lg-WT-H9556
LG WM Washing... | Answered on Mar 29, 2017
There is no need to raise the water level. all modern washers automatically add the amount of water needed to wash the amount of clothes that you put in, I could explain how, but it will put you to sleep. rest assured these machines pretty much look after themselves. I would be more interested to know why you think it needs more water, are you having rinsing issues? wash quality issues?
LG WM Washing... | Answered on Oct 18, 2016
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel.
Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
LG WM Washing... | Answered on Aug 15, 2016
LG SteamWasher WM2801H Front Load Logo
Popular Tags
17 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
machine flooding while not in use drum
  • Washing Machines
