20 Most Recent Garmin nuvi 1490T GPS Receiver Questions & Answers
2answers
How do I register my brand new Garmin?
go to the garmin site register your unit use the pc connect the usb cable to the phone it will self setup there is a software setup for the 1490t i did mine 2 days ago , still can't figure out the software for doing your own routing etc but to register it follow the above
graham
11/14/2022 8:50:15 AM • Garmin nuvi... • Answered on Nov 14, 2022
2answers
Garnin 1490 nuvi will not power up
Sounds like the battery pack has failed or the charger was not correct voltage and you burned out the unit. I would go with the battery, they are very cheap. Takes about 15 minutes to replace it.
10/13/2022 6:27:57 AM • Garmin nuvi... • Answered on Oct 13, 2022
3answers
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
9/9/2022 7:24:06 AM • Garmin nuvi... • Answered on Sep 09, 2022
2answers
How to charge my gps garmin 1490t?
You can download the manual here. Charging instructions are on page 48.
Depending on the package you purchased, you may have a USB cable. If so, connect the cable to your n?vi and your computer USB port. USB hubs may not be capable of charging the unit.
If you do not have a USB cable, and are not able to charge the n?vi in your car, the fuse in your car vehicle adapter may be bad. You can unscrew the black round end piece from the adapter. This will be on the end that goes into the lighter/power socket. Be careful not to loose the silver cap. The fuse is spring loaded and may pop out. The proper replacement fuse type is indicated on the side of the vehicle adapter.
Garmin also offers an optional AC adapter that can be used without a computer.
9/9/2022 6:25:33 AM • Garmin nuvi... • Answered on Sep 09, 2022
Problem registering garmin nuvi 1490T. after
it will be getting the satnavs drivers online for it to work.let it do for a while it should work eventually
2/11/2018 2:59:25 PM • Garmin nuvi... • Answered on Feb 11, 2018
My garmin nuvi 1490t keeps
connect it to a computer and purchase the maps that you need,if it is new,it will download what it needs for free
5/13/2017 1:21:30 PM • Garmin nuvi... • Answered on May 13, 2017
How do i set up my garmin nuvi 1490T udates on a different computer
I assume that since you've successfully updated your GPS previously (from your question), you must have a Garmin account, registered your unit and Garmin Express installed. With GE installed on your new computer, you should have no difficulty continuing to update your nuvi.
12/4/2016 11:33:46 PM • Garmin nuvi... • Answered on Dec 04, 2016
Garmin Nuvi 1490- I have
The pictures must be in the "JPEG" folder of either the GPS's internal memory or external SD card to display. Acceptable formats are: JPEG, BPM, GIF, BNG, TIF, and others.If you are having trouble, resizing and / or reducing the number of colors in the picture may help. If you save or convert the image to GIF, it will automatically be reduced to 256 colors.
10/9/2015 2:06:33 PM • Garmin nuvi... • Answered on Oct 09, 2015
New battery replaced and Garmin comes on and shuts off within seconds
Try to charge battery some time if that don't work,they should refund it,or send you again new battery which is tested and works.
1/4/2015 10:33:43 AM • Garmin nuvi... • Answered on Jan 04, 2015
Where can I get a replacement mini usb port for my GPS?
if you are talking about the interface cable, try Ebay or contact Garmin to purchase a replacement cable.
11/23/2014 4:25:37 AM • Garmin nuvi... • Answered on Nov 23, 2014
How to get our Nuvi 1490 to work in Pennsylvania ?
If you have complete U.S. map installed on your device it should work in Pennsylvania too.Best regards.
9/12/2014 9:38:17 AM • Garmin nuvi... • Answered on Sep 12, 2014
0answers
Dont reconize my garmin usb
what are you connecting your garmin usb to?
7/28/2014 9:50:33 AM • Garmin nuvi... • Answered on Jul 28, 2014
How to garmin hard reset?
you do realize humans answer these qusetoins.. "how do I..." sounds a whole lot more normal. for the 1400 series devices you power it on while holding the lower right corner of the touch screen. It should say "do you really want to erase all user data?" and you just say yes. This can solve weird issues but will erase all your data and will never change the maps. Also sets all settings to the default.
7/20/2014 3:56:05 PM • Garmin nuvi... • Answered on Jul 20, 2014
How to remove ribbon cable from Garmin Nuvi 1490
Try this link for a pictured breakdown of Kindle Fire HD. https://www.ifixit.com/Teardown/Kindle+Fire+HD+Teardown/10457 There's also directfix.com which has some help.
7/12/2014 2:58:02 PM • Garmin nuvi... • Answered on Jul 12, 2014
Garmin nuvi 1490T GPS Receiver Logo
392 questions posted
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
change battery
  • GPS
