Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll. hope this helps
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode. Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
click start type cmd press enter
At command prompt type debugyou will get a - prompt where you can type the following (<enter> means press enter not type enter*)A <ENTER>MOV AX,0 <ENTER>MOV AX,CX <ENTER>OUT 70,AL <ENTER>MOV AX,0 <ENTER>OUT 71,AL <ENTER>INC CX <ENTER>CMP CX,100 <ENTER>JB 103 <ENTER>INT 20 <ENTER><ENTER> just hit enter on this lineG <ENTER>Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
Hope it helps
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of chargehope this helps you
77 questions posted
2,767 Questions
2,074 Questions
1,822 Questions
1,740 Questions
1,432 Questions
