20 Most Recent Gevril 2 MENS MASTERPIECE AUTOMATIC WATCH 4140L Men Watch for Men Questions & Answers
Good day! i bought this watch for my brother on
Unfortunatly, He will likely need to purchase a long strap. Perhaps the point of purchase can assist you, or many generics are out there and generally available form independant jewelers.
10/6/2014 9:19:25 PM • Gevril 2 MENS... • Answered on Oct 06, 2014
How may I access a Gevril Canal Street operating manual?
Try their customer service for this. I don't find the manual elsewhere. Gevril Canal Street Bold Automatic Diver
10/23/2023 10:07:53 AM • Gevril Watches • Answered on Oct 23, 2023
I took my Gevril watch to a watchmaker to reduce the links. Despite his best efforts he was unable to remove any. Where can I take it? What can I do?
Contact Gevril direct with a view to returning it to them, or finding an authorized repair outlet. That is a pretty watch! https://www.gevril.com/products/12404 Call Us: (866) 6-GEVRIL (866-643-8745) Email Us: [email protected] ..
10/16/2022 7:31:09 PM • Gevril Watches • Answered on Oct 16, 2022
How to change the month on the Gevril R007 automatic watch?
Ask the company direct. Normally the crown has 2 positions. Call Us: (866) 6-GEVRIL (866-643-8745) Email Us: [email protected]
2/25/2022 5:50:01 PM • Gevril Watches • Answered on Feb 25, 2022
0answers
0answers
I have a GEVRIL GV2
This the step to follow to lengthen a bracelet steel.
Try the bracelet on your wrist. Determine how many chain links you want to add to the bracelet in order to make it fit better. Remove the bracelet from your wrist. Keep the bracelet unfastened. Lay it out in a straight line on a flat surface.
Separate one portion of the clasp from one end of the bracelet. Bend open the small ring that connects the clasp to the end link of the bracelet. Pull off the clasp and set it aside.
  • Read more: How to Adjust Stainless Steel Bracelets | eHow.com http://www.ehow.com/how_6188855_adjust-stainless-steel-bracelets.html#ixzz0toMhOrGa
    Recall how many links you decided to remove from the bracelet. Obtain the same number of stainless steel jump rings. Metal rings that open and close and are frequently used as jewelrymag-glass_10x10.gif components. Choose stainless steel jump rings in a size and gauge that matches the size and gauge of the existing links of your bracelet.
    Open a jump ring slightly with pliers. Hook the jump ring onto the end link of your bracelet. Close the jump ring with pliers. Continue this process until you have added as many jump rings as you require to make your bracelet long enough.
    Reattach the clasp to the end jump ring of your newly lengthened bracelet. Slip the small ring that connects the clasp to the bracelet onto the end jump ring. Close the ring over the jump ring with pliers.
    Goodluck
    7/16/2010 10:17:51 PM • Gevril Watches • Answered on Jul 16, 2010
    Second hand stops.
    If you want to do it yourself you have to get the movement out first. When its done, take tweezers and carefully lift the seconds hand by the pointed end. Hand is made of flexible material and will not brake if lifted just a tiny bit.
    Rate, please.
    7/29/2009 2:44:22 AM • Gevril Watches • Answered on Jul 29, 2009
    Are accutime watches waterproof
    What a question. ... The back of the watch will give details and it depends upon the model of watch. Some are, some aren't.
    4/26/2024 6:24:24 AM • Watches • Answered 4 hours ago
    Sector adv 1000 manual
    ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH. NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position. 1) Set the crown at the normal (in) position. 2) Push the B button twice. 3) Pull out the crown to the 2nd position (fully out). a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position. b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position. 4) Push the crown back in to normal position. QUICK-SET OF THE CALENDAR DATE With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date. sector adv1000 zero-setting & date instructions-undefined-undefined-0.jpg
    4/25/2024 5:30:35 PM • Watches • Answered 17 hours ago
    I'de like to have a
    Si porque tengo este reloj
    4/17/2024 7:04:45 AM • Watches • Answered on Apr 17, 2024
    2answers
    How do i take my george watch out of 24 hour time?
    how do you set the time on the digital george watches?
    4/11/2024 7:38:43 AM • Watches • Answered on Apr 11, 2024
    My pearl necklace has broken
    Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
    Thank you for contacting FixYa.
    Jewel
    4/7/2024 2:26:15 AM • Watches • Answered on Apr 07, 2024
    BASE, METAL BEZEL STAINLESS STEEL BACK 10/4312-13 75311 THAILAND MOVT WATER RESISTANT 100F1 QUARTZ
    Question edited for clarity. Please don't type in all CAPS, it is considered SHOUTING and is harder to read especially in a jumble of words and numbers. 377, although a maker would be useful! https://www.google.com/search?q=battery+METAL+BEZEL+STAINLESS+STEEL+BACK+10%2F4312-13+75311+THAILAND+MOVT ..
    4/6/2024 1:45:42 AM • Watches • Answered on Apr 06, 2024
    2answers
    U.S. Polo Assn. Sport Men's US9061 Black Rubber Strap Watch. I need the INSTRUCTION MANUAL FOR bc534-1741el please.
    No manual, just this. You can however just search by the number of buttons, 2 , 4 or 4. They are all the same. Google 4 button chronograph watch manual
    4/5/2024 10:45:51 PM • Watches • Answered on Apr 05, 2024
    Would like to check serial number on ferrari watch
    yes
    4/3/2024 8:07:40 AM • Watches • Answered on Apr 03, 2024
    CANDINO WATCH 10965 PLAQUE G 10 WF. Is it made of gold please.
    Question edited for clarity. Please don't type in all CAPS it is considered SHOUTING. No, they are gold plated. https://www.google.com/search?q=CANDINO+WATCH+10965 ..
    3/22/2024 2:45:09 AM • Watches • Answered on Mar 22, 2024
    Gevril 2 MENS MASTERPIECE AUTOMATIC WATCH 4140L Men Watch for Men Logo
    1 questions posted
    Top Gevril Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Gevril Watch Expert? Answer questions, earn points and help others
    View Most Popular
    Gevril Watches
    • Gevril Watches
    Most Popular Question
    good day bought watch brother
    • Watches
