20 Most Recent Bernina Virtuosa 160 Questions & Answers
2answers
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
11/12/2023 10:27:16 AM • Bernina Virtuosa... • Answered on Nov 12, 2023
2answers
My Bernina 1090 in which I have had for 20 years
if you just had it serviced & it has not been 30 days, I would take it back & have them check it again.
if that's your only sewing machine, I would recommend that you get another machine as a back up or a new machine & use the other as a back up
I have a mechanical & electronic sewing machine, that way if I'm servicing one I can use the other
11/11/2023 11:11:36 AM • Bernina Virtuosa... • Answered on Nov 11, 2023
3answers
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
8/17/2022 6:06:52 PM • Bernina Virtuosa... • Answered on Aug 17, 2022
Needle threader not lining up with eye of needle
On mine, I just pushed the needle threader to let it line up with your needle when you have the lever down, look at the little wire to see what it is hitting on the needle. My first machine with a needle threader had the little wire missing so I thought that I was doing something wrong, luckily JoAnn's had a Viking store inside and she showed me. So, I called Singer and they sent me a new one.
2/4/2018 7:34:02 PM • Bernina Virtuosa... • Answered on Feb 04, 2018
I tried to use a
When you thread the top thread, ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk. If this doesn't improve the stitch, try tightening the top tension. If it is too loose, the bobbin thread will lay on the surface of the fabric. When the top tension is tightened, it will pull the bobbin thread up into the fabric.
2/4/2018 2:47:30 AM • Bernina Virtuosa... • Answered on Feb 04, 2018
The humming noise the Bernina 350 makes when first
Is your bobbin winder on?
I get that one in my shop about 1-2 times a mounth.
9/1/2017 9:15:36 PM • Bernina Virtuosa... • Answered on Sep 01, 2017
2answers
My School has blocked Runescape with NETSPACE,
firstly you prob shouldntb on runescape at school secondly your not gonna be able to get on to it uless u have the admi pass which im guessing u dont
10/20/2016 2:59:28 AM • Bernina Virtuosa... • Answered on Oct 20, 2016
2answers
I am trying to locate (and download) a free Bernina Virtuosa 160 manual
https://www.bernina.com/de/SupportData/BERNINA-Nah-und-Stickmaschinen/BERNINA-8er-Serie/880/034791-50-04_Manual_B880_EN_online Hi. I hope this link can help you. im not sorry about the content if is relevant in question :(. thanks
7/6/2016 2:58:29 PM • Bernina Virtuosa... • Answered on Jul 06, 2016
3answers
Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
3/27/2016 4:19:43 PM • Bernina Virtuosa... • Answered on Mar 27, 2016
What foot do I use to use the letters?
You'd probably want to use an embroidery foot. Go to the Bernina web site and look through the different presser feet. http://www.bernina.com/getdoc/0a4a6cbd-49ea-4a82-ab6a-32bd16dc049c/Bernina_Zubehoerkatalog_Inet_EN_v2 ...
11/17/2015 11:02:01 PM • Bernina Virtuosa... • Answered on Nov 17, 2015
How to sew buttonholes
Do you have a manual? If not, here is one that may help: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFYQFjAHahUKEwjt_Pq0sZDJAhUCV4gKHWIiDSc&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&bvm=bv.107467506,d.cGU&cad=rja However, it appears from some user reviews that this model seemed to have some issues with the buttonhole:http://sewing.patternreview.com/SewingDiscussions/topic/45400/1...
11/14/2015 5:00:40 PM • Bernina Virtuosa... • Answered on Nov 14, 2015
How much does one sell for
The selling price is greatly dependent on the physical and working condition and the accessories included. If the one you have is really nice, you might try selling it on Craigslist instead of eBay because Bernina afficionados will pay a good value if they are able to visually see and test the machine. However, some people on eBay pay way too much for a machine they have seen only in pictures. Bernina Virtuosa 160 Sewing Machine Switzerland If you thinking about getting another machine, you may want to check into trading it in. ...
10/5/2015 6:56:59 PM • Bernina Virtuosa... • Answered on Oct 05, 2015
2answers
Looping stitches
Hello Shirley, I suggest you make sure the machine is threaded correctly. If you have a factory manual, that would be a help. It sounds as though the needle thread is not threaded through the take up arm and/or take up arm spring. The needle thread tensioner might be too loose.
6/5/2015 5:01:07 PM • Bernina Virtuosa... • Answered on Jun 05, 2015
2answers
My wonderful Bernina 1130 has
Contact an authorized Bernina dealer/repair center. The service technician can often tell what board needs to be worked on, take it out and send to Bernina. I just had to have work done on my 1130 and that is what was done. If that does not work, look up the number and call Bernina USA directly so they can direct you. While it's true that some parts are no longer obtainable, the machine boards can be serviced by Bernina USA. It's worth fixing.
3/2/2015 9:43:16 PM • Bernina Virtuosa... • Answered on Mar 02, 2015
4answers
Do I have to buy a Bernina foot in order for it to
Yes. Bernina feet aren't interchangeable with other machines and non-Bernina feet won't fit a Bernina. Sorry.
Robbie
2/13/2015 6:44:49 PM • Bernina Virtuosa... • Answered on Feb 13, 2015
Where can I find an instruction manual for bernina virtuosa 160?
Here is a link to a sewing machine part company where you can order the manual. It is $19, but I think well worth it if you have the machine. Good luck! That is a nice little machine. http://www.sewingpartsonline.com/instruction-manual-bernina-virtuosa-160.aspx
11/25/2014 7:57:32 PM • Bernina Virtuosa... • Answered on Nov 25, 2014
What is presser foot 37 for
The Bernina foot 37 is called the 'Patchwork Foot'. It is very useful in piecing quilt tops as the foot features an accurate 1/4" and 1/8" on both sides of the needle. It also has a 1/4" guide in front and behind the needle to allow accurate 1/4" stops and starts from the end of the pieces being stitched together. An excellent reference guide is available on line at: http://berninainstitches.com/pdfs/Bernina_Presser_Feet_Guide.pdf
10/13/2014 11:30:39 AM • Bernina Virtuosa... • Answered on Oct 13, 2014
Where can i get a free manual
Google it for your machine make and model.
7/21/2014 5:30:45 AM • Bernina Virtuosa... • Answered on Jul 21, 2014
Sewing Machines Logo
148 questions posted
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bernina Sewing Machines
Most Popular Question
bernina 160 stops brief second while
  • Sewing Machines
