20 Most Recent
Philip Stein Teslar Stainless Steel Small Watch 1-G-CI-SS Questions & Answers
Battery replacement
If you have a warrantee with your watch you may have to return thew watch to the manufacturerer for battery replacement. Othet than that, most any jeweler can replace the battery. Mike D 75
Both faces have stopped (need
In the event you need to have your Philip Stein Watch or Bracelet serviced, we recommend contacting one of our Authorized Repair Centers (ARC). We have over 100 locations around the world that will be able to assist you with a range of services from battery replacements, to more sensitive repairs. Please use the Store Locator section to find an ARC in your area (be sure to select "Repair Center" when looking for a repair facility). If you are unable to locate one, or have trouble using the Store Locator section, please feel free to view the full list of Authorized Repair Centers, otherwise, you may contact our After Sales Customer Service department to discuss alternative options. They may be reached via email at service@philipstein, or telephone by dialing 305-373-0037 between the hours of 9AM - 5PM EST.
My husband purchased a new PS watch, that doesn't
Kinetic dive watches utilize motion, or kinetic energy from watch or hand movement. If there is inadequate movement to keep the watch going.
RECOMENDATION:
1. Involve some much needed physical movement (Physical Training) that will both help the wearer and the watch with the watch being the judge of if he is moving enough every day?
2. Get a battery powered watch.
Number one is a better solution.
Hope this tip helps.
r/
David
Sector adv 1000 manual
ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH.
NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position.
1) Set the crown at the normal (in) position.
2) Push the B button twice.
3) Pull out the crown to the 2nd position (fully out).
a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position.
b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position.
4) Push the crown back in to normal position.
QUICK-SET OF THE CALENDAR DATE
With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date.
4/25/2024 5:30:35 PM •
Watches
Answered
13 hours ago
