20 Most Recent
Cerruti Genova Swiss #CT69051X403021 Watch for Men Questions & Answers
I need change the glass.where?
It is possible for jewelers to order exact fit replacement crystals for many watches. However, generic replacements are not made for all watches. If your jeweler cannot perform this service (which may cost as little as $10 for common crystals), ask if the jeweler knows of a jeweler's specialty business that can custom-fit crystals. These small shops custom-grind crystals from blank stock and hand-fit them to your watch. Such companies used to be relatively common; today, most conduct operations via mail-order or exist in large cities like New York where there is enough local wholesale and walk-in business.
Department stores and chain jewelry stores rarely have the on-sight resources to service a broad selection of watch crystals. Seek out an independent jeweler or one that has a "we repair watches" sign displayed.
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
I have a Cerruti watch,
I haven't instructions for this particular watch, but I have adjusted other chronograph type watches that had this problem. If you pull out the stem for adjusting the ordinary time hands, you can advance the stopwatch hands by pressing the stopwatch start/stop and reset buttons. Once they are in the right rest position, push the time setting stem back in.
You will probably have to experiment with this, particularly if you also have a date on the watch. When I first did it, it took hours because I kept doing things in the wrong order, but if you keep at it, you can sort it out.
Bijoux Terner Sport watch RO616F
I got one of these on a cruise, and I had the same issue, and searched on the web just now (7/26/08 9:20pm) and could not find an answer.....so, I just sat here for a few minutes to push all the buttons...
Mine has 4 buttons at the 2, 4,8,10 positions....corresponding to "start", "reset", "mode", "light"
Hold down the "start", then while holding it down, push the "reset" button.....voila!
