20 Most Recent
HP Mini 1000 VT series PC Notebook Questions & Answers
HP Mini 1000 VT won't turn on, lights flash when plugged in
Hello,This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information. With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data) Worst case, you may need an authorized HP agent to service your pc. Good LuckC2Soluitons
Do i need to disconnect charger for a factory restore?
NO , never,
if the big laptop , is old NONE TOLD, and that huge battery is bad as most are old, I'd remove it and run on only the AC/DC power pack
alone.
laptops PCs have to have bad huge batteries even 1 year old abused.
charger = AC/DC POWER PACK.
The charger is actually deep inside the PC> (a chip by same name)
no PC told but if you read the manual ,chapter recover, sure
it many leave out details, they assume the PC is 100% hardware prefect and is only a dream of data only geeks.
5/2/2022 11:54:23 AM •
HP Mini...
Answered
on May 02, 2022
How do we find out how to get our login information so that we can log on to the internet?
what a great question and so clear !!
well there are only 2 ways. (safe)
1: call your ISP and ask them. if they
own the router ask them.
some IPS put sticker tag bottom? of PC with credentials.
2: if however the router is
owned by you, the answer is inside YOUR router, and is covered in your Router manual, by exact model #
the 3 things to set are
- SSID (broadcasted name) I use dogs name use a name only you know so when seeing 50 others in the hood you know right away that REX123 is you.
- set encryption to WPA2
- SET WIKI PASS PHRASE TO WHAT YOU WANT, and is case sensitive...
- never use AD HOC mode or open wifi if seen.
- nor WEP
- nor WPS or PIN.
go to makers web site if router is netgear go there. get your free manual and keep it PDF.on your PC.
then read settings page.
5/1/2022 2:55:21 PM •
HP Mini...
Answered
on May 01, 2022
Vox mini laptap reset factory
hp.com
tell them pc model full, you did not.
find manual there
read it
chapter RECOVERY.
if lost ask on there forum hp.com
1/14/2022 9:59:29 PM •
HP Mini...
Answered
on Jan 14, 2022
Hp mini 210-1170nr
check that the ribbon it may have come back out or its not put back right.
check the wires on the inverter and make sure all wires and ribbons are all in place.
4/14/2015 6:33:39 PM •
HP Mini...
Answered
on Apr 14, 2015
How can i download free video to my mini hp laptop
Download Chrome web browser and FVD Downloader software. Install them on your HP laptop. Then click the icon at left upper corner of the browser window while the free video is playing. Out of the listed media, you can select the media to be downloaded.
1/6/2015 11:21:03 AM •
HP Mini...
Answered
on Jan 06, 2015
Hp mini remove battery
From what I can tell without the specific model number (as there are numerous HP Minis), the battery is built in similar as it is for a tablet. It would require dismantling the mini-laptop from the under-side, effectively voiding any warranty.
8/18/2014 10:18:09 PM •
HP Mini...
Answered
on Aug 18, 2014
How to speed up hp mini free?
if hp mini is slow,first check maybe you have a active anti virus installed on your system.
2. check maybe you two different type of office that is office 2003 or office 2007 on your system
8/1/2014 11:49:14 AM •
HP Mini...
Answered
on Aug 01, 2014
Password to os for hp min 110-1197TU
If you can open up the PC and carefully, remove the Button Cell battery on the mother board, wait 15 seconds and then reseat the battery, your problem will be solved. You need to go into the BIOS menu and click save and reboot. Boot up in Safe Mode, and go to control panel - Users - and enter a new administrator password. If you are the only user, you dont need to enter any password.
7/31/2014 3:43:30 AM •
HP Mini...
Answered
on Jul 31, 2014
Wont start when I push button.
Make sure when you put it back together that you did not forget to plug in the power button or button cable. Also the battery may not be charged if it is new. Batteries do not hold charge being li-ion for a long period of time.
4/21/2014 10:58:02 PM •
HP Mini...
Answered
on Apr 21, 2014
