20 Most Recent
HP 2133 Notebook PC Questions & Answers
Hp g62-407dx booting from external mode and black screen
it is not a black screen if there is white text errorsthe PC is computing ! (it is NOT dead)the PC screen works and the HP splash works.(not dead)yes windows is dead, but that be LAST.the PC BIOS pages are not deadif it texted and error PXE bla bla then the RTC coin cells is dead.(fix that now)if a true black screen happened that is gross power failureand all above is dead, no text, ever.the test is simpleg61 only, Hp changed hot keys 2015?BIOS hot key is ESC power on, hammer ESC . hammer at the HP slash screen gently and bingo F10 prompt happens so press f10to to boot order pagemake HDD0 first. hard disk drivesave exit. cold boot it.no CD in trayno thumb drives or other odd USB things.if HDD boots then be happy, but that dead coin cell all this happens again. (ac gone and big battery dead or out)if hDD fails to boot, forcedwe run HP diagnostics on the hDD.and many do fail, no surprise that.a 2010 made PC.this PC haS 2010 ccfl back lamps and most are deadthe PC in that case we can force it to external desplay VGA jack. to a real monitor, and see PC is working.
Locked out of my hp mini---forgot password
is this the password to log into the computer, password for BIOS or Power on passwords......
- if power on passwords or BIOS passwords, remove CMOS battery and leave it out for 30 minutes then slot it back, that will reset all passwords and set all system to defaults
- if log in password, click on ctrl+alt+del twice then type in administrator on the username and press enter....
- STEPS
- username:Administrator, password:blank (do not type anything). then press enter.
- go to control panel then select Administrative Tool
- click on Computer Management
- Click on Local USers & Groups
- Click on Users
- Right-click on your username on the right pane then select SET PASSWORD
- change password, apply ,OK.
- log off then log into your account
Forgot password for HP LAPTOP NOTE BOOK
The CMOS battery on an HP NoteBook is incredibly difficult to access. It is located under the motherboard, which means that EVERYTHING must be taken apart just to get to it. Been there, done that, tempted to just make a hole in the back of mine just for that reason.
As for a Windows password, those can be reset fairly simply. There are softwares (many good ones are free) that you boot up from a usb or cd and go from there.
It is even very easy to reset such passwords manually by first booting up into safe mode (not so easy to do in Win 8 though, sorry) and running the command line interface cmd.exe with elevated privileges by right-clicking on it and then run as administrator.
Enter the command: net user
This shows you all of the user accounts on the system. You will see in the list of users the account you selected a name for and a couple others like Guest and Administrator. These two are deactivated by default, but may be activated and used.
Reset the password for a user account by entering:
net user (UserName) (UserPassWord) active:yes
Note: (UserName) refers to the name of the account you are working on, and be EXTREMELY careful when typing the password. This method will not forgive any typing mistake. It will just do what you typed in. There is no OOPS button here!
Those are the two options, manually in safe mode or boot a password reset program. Many of these are free.
If you are resetting a user password for Windows 8 though, it will take a lot of searching and trying different programs. Many say they are compatible, but , , , :-)
How to reformat hp 2133
You will need an external USB DVD rom - recommend W7 premium - plug in the dvd rom power the unit up - hit F9 to select boot device - fit your dvd into the dvd rom then select the dvd rom as the boot device and follow the instructions. W7 has 99.9% of the drivers within the SOE to enable the devices for mini's are very basic
How do I disable the touchpad on my hp probook 4530s?
03-27-2013 FINALLY A SOLUTION THAT WORKS TO DISABLE HP 4530S touch pad:Clickity click on Control Panel/System/Device Manager/Mice/Synaptics PS2/Driver/Update Driver/Search Internet for latest driver.It should find and update with driver dated 01/10/2013 which is driver version 16.3.9.0HOORAY! Double click on the upper left hand corner of the mouse pad, the light comes On indicating that the mouse pad is OFF - and it works just like HP said it would two years ago. Knowing HP, who knows for how long it will work.This works on Windows 7 - on other systems your milage may vary.
Bootmgr mising hp
Use the Restoration Disk.When asked choose Repair. Non-Destructive Installation.Don't have the disk?Example from USA;The disk is free. The shipping and handling is not.$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.Call 800-474-6836, 24 hours a day, 7 days a week.Have the Serial Number written down, to give to the nice representative. This is in the white Service Tag, on the Bottom of the laptop. S/N = Serial Number.[NOTE*Do NOT post the serial number on a world wide public forum.ONLY give to an authorized HP representative ]For all countries use HP Support Worldwide, for the contact phone number,
http://welcome.hp.com/country/w1/en/support.htmlThe Restoration Disk will just repair the basic Windows files.Boot Manager is one of them.Regards,joecoolvette
*0# keys not working
The only way to fix this, the keyboard must be replaced, no serviceable parts. Go to
www.ebay.com Type: make and model of your laptop refine search to keyboard.
How do i turn on
Hi colinmckee12...
Follow the instructions below to use your webcam
Click on Start then >Control panel>hardware and sound >device manager>imaging devices>web cam....enable it
Another way is to use a IM application like Yahoo messenger,NetMeeting,etc. They will have video capabilities that will work with your webcam.
Please take time to rate me thumbs up
