20 Most Recent
Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan Questions & Answers
A couple years ago I
How outside is the fan? The blades should be a plastic type material. They should not break just because of it being outside. Go to the nearest hardware store and tell them you need some exterior fan blades. Screw them in to the metal arms that connect to the fan and make sure you have all exterior and rust proof parts (screws, fan blade arms, etc). Make sure to tighten the screws good. Then screw them into the fan motor, tightly of course. These should not break. If it continues to break after replacing the blades, then it would seem as if someone or something is breaking them. I've been an electrician for 8 years and have never heard of this happening.
Need to uninstall the fan as it has become a bit
The first thing to do is loosen the ceiling canopy, there is usually a couple screws at the top edge of the canopy. then you want to disconnect the wiring, do not forget the green wire also. then depending on the mounting type, it may just lift out, one side of the mounting bracket has a space to allow the ball to pass thru. Or you may have to unscrew a couple mounting screws at the ends iof the mounting bracket
Chain switch broke
The light fixture then the fans lower housing needs to be removed to gain access to the pull chain switch
Need new glass shade for hampton bay tahiti breeze
Hampton Bay is a Home Depot product. Many Home Depots carry these replacement shades in stock. If your Home Depot doesn't have this shade in stock they can order one for you. Regards, Joe
PS Please rate my answer. Thank you.
I have an outdoor Hampton Bay Four Winds 54 inch
Call Home Depot customer service dept at 1-800-654-0688 and they will put you in touch with the manufacturer while on the phone. These fan have a problem with the motor control module, but they will send you the replacement part for free.
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
- push it up and turn (like when you open a medicine bottle.
- try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
