20 Most Recent Makita Hm1307cb Demolition Hammer, 1 1/8 In Hex, 35 Lb 14f120 Questions & Answers
Makita 35lb breaker wont hammer. Power light turns on but wont hammer.
Most likely it is the brushes - most of their models in that series have auto-stop brushes that push away from the armature when they reach a certain wear point.
3/3/2021 2:39:20 PM • Makita Hm1307cb... • Answered on Mar 03, 2021
Makita avt hm1214c jackhammer. Where do I add the oil?
https://www.manualslib.com/manual/585142/Makita-Hm1214c.html?page=5#manual
1/29/2022 12:48:13 AM • Makita Hammering • Answered on Jan 29, 2022
Jack hammer makita hm1304 lubricant used
Makita A-90582 or (the equivalent)
Hitachi 981840 Hammer Grease
But dont forget to replace all o-rings and seals at the same time some older models have special wear tear parts sets for service also called maintenance spare parts. If the brushes are short then its time for service.
12/2/2019 7:41:04 PM • Makita Hammering • Answered on Dec 02, 2019
Tool wont scrape
254031-3 pos14 part inlay key can be damaged pos 11 drive rod 315146-2 can broken IF mechanical damage or dried out by leaking gasket / orings. For better repair use after a repair of some parts an maintenance kit 193394-1 If the working hours are on it, but also after an repair on other parts because leaking tools can be dried out and give cured o rings in a very short time by building up overheat temperature inside and will not build up pneumatic power it will not do the job and is not good for physical strain.
10/2/2018 6:20:27 PM • Makita Hammering • Answered on Oct 02, 2018
Does a makita electrick. Jackhammer take oil or grease and where does it go
The GREASE for this heavy jackhammer Makita 181490-7 Grease (if there are short carbon brushes to find ) replace all orings gaskets (and looking for an maintenance kit for this machine) 188015-8 thats the better way to service.
9/12/2018 5:23:39 PM • Makita Hammering • Answered on Sep 12, 2018
Makita HM1211B 20-Pound Demolition the motor work but not hammer
Connecting rod Part Number: 315419-3 or Woodruff Key 4 Part Number: 254001-2 Makita HM1211B Parts List and Diagram eReplacementParts com Or broken spindle/ worn bearing(s)
8/12/2018 10:24:29 AM • Makita Hammering • Answered on Aug 12, 2018
My Makita HMO810B Demolition hammer Smkes and burning wire smell help
burning motor take it in for a check or junk it
7/7/2018 11:21:50 PM • Makita Hammering • Answered on Jul 07, 2018
How to grease a makita mt m8600 demolition hammer
Order an maintenance kit for it , when the working hours are on the tool , all given parts in the kit must be replaced its not a good idea to only grease it, the tool should not leaking by the chisel. then there will be a bad break-force and give a long working job..
3/1/2018 4:38:24 PM • Makita Hammering • Answered on Mar 01, 2018
Help what kind of oil can i used in makita jackhammer oil HM0810T
Makita 181490-7 30grams
1/30/2018 5:21:42 AM • Makita Hammering • Answered on Jan 30, 2018
I have a PH65A Makita hammer demolition and it start working for about 10 seconds breaking and after that the hammering power slow and losses it's power hit even that motor keeps working, why?
first ordernumber 931848 lubrication necessary it has its working hours on it. parts to change in priority 1 x 944-927 , 949457Z , 956-960 , 944-936 , 956-965 , 999032 , 956-996 , 944-928 the important thing is that the machine is airtight at the front so as not to burn the O-rings through the air and incoming dirt friction look the orings good and if the lock bolt on the front feel not smooth replace that also and every oil seal you can find its different what should neccesary but that the tool runs with thick and dirt beaten oil . solvent clean the hard metal parts and replace if there are grooves on or cracks Hitachi PH 65A Demo Hammer Parts
3/17/2016 4:04:01 AM • Makita Hammering • Answered on Mar 17, 2016
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
3/16/2016 8:16:19 PM • Makita Hammering • Answered on Mar 16, 2016
Its turing on but wont hammer
something broken , or only dry, leaking (o-rings hard or burned inside) or the armature drive is worn .
3/16/2016 8:09:42 PM • Makita Hammering • Answered on Mar 16, 2016
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387 For outside chisels Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
3/16/2016 8:07:45 PM • Makita Hammering • Answered on Mar 16, 2016
How do i lubricate my makita hr2450 hammer
193606-2 its the neccesary service kit for the tool with all the parts but be aware to control the locking sleeve and impact bolt replace it if its not air tight
3/16/2016 8:03:32 PM • Makita Hammering • Answered on Mar 16, 2016
HOW GOOD IS H65SB2 HITACHI?
As long as its last and the endurance of the worker in first place . Its better then use rotating hammers at a long lasting working order , because of the price the choice of a demolition hammer is always a great difference because of the time you can spend , there are much Chinese models look a like this hammer its popular also bosch models you will see . chinese demolition Google zoeken
3/16/2016 7:36:40 PM • Makita Hammering • Answered on Mar 16, 2016
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:- Hammer Grease 90582 for Makita Power Tool eReplacement Parts
2/11/2016 2:43:05 PM • Makita Hammering • Answered on Feb 11, 2016
Type of oil use for demolition hammer
A old black graphite or yellow grease lubrication of the brand Makita
1/2/2016 1:59:37 PM • Makita Hammering • Answered on Jan 02, 2016
My makita hm0810b has stopped hammering
193242-4 Revisionkit
12/18/2015 5:20:59 PM • Makita Hammering • Answered on Dec 18, 2015
2answers
Where do I ad oil to a makita hm1500 demolition
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
12/3/2015 4:13:59 PM • Makita Hammering • Answered on Dec 03, 2015
0answers
Makita Hm1307cb Demolition Hammer, 1 1/8 In Hex, 35 Lb 14f120 Logo
1 questions posted
Top Makita Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Makita Hammering Expert? Answer questions, earn points and help others
View Most Popular
Makita Hammering
  • Makita Hammering
Most Popular Question
makita 35lb breaker wont hammer power
  • Hammering
