20 Most Recent
Makita Hm0810b 11-pound Demolition Chiseling Hammer Questions & Answers
YOU PROB APPLY TOO MUCH FORCE ON IT
THE PISTON PROB GOT DAMAGE
THAT EXPLAIN THE SMELL HAVE IT CHECK OUT BY A PROFESSIONAL.
Tool wont scrape
254031-3 pos14 part inlay key can be damaged pos 11 drive rod 315146-2 can broken IF mechanical damage or dried out by leaking gasket / orings.
For better repair use after a repair of some parts an maintenance kit
193394-1
If the working hours are on it, but also after an repair on other parts because leaking tools can be dried out and give cured o rings in a very short time by building up overheat temperature inside and will not build up pneumatic power it will not do the job and is not good for physical strain.
How to grease a makita mt m8600 demolition hammer
Order an maintenance kit for it , when the working hours are on the tool , all given parts in the kit must be replaced its not a good idea to only grease it, the tool should not leaking by the chisel. then there will be a bad break-force and give a long working job..
HOW GOOD IS H65SB2 HITACHI?
As long as its last and the endurance of the worker in first place .
Its better then use rotating hammers at a long lasting working order , because of the price the choice of a demolition hammer is always a great difference because of the time you can spend , there are much Chinese models look a like this hammer its popular also bosch models you will see .
chinese demolition Google zoeken
