20 Most Recent
Wrangler Soft-top Plastic Window Cleaner, Mopar Questions & Answers
I need to remove a Super Console Drawer from a
There is a hidden flap door on the front end of the console (in the area where there is a cubby with flexible mesh around it). Like a gas cover, lift up at the point where the flap has a small lip in it. Easy access after that. This only involves the large pull out drawer. Wish I could say I was smart enough to figure this out but, in reality, pushing on the sliding drawer forced the dvd case trapped inside to push forward and pop open the flap.
9/5/2019 2:05:54 PM •
Wrangler...
Answered
on Sep 05, 2019
I need some explanation about
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Tranny fluid hose explodes
Is this the cooling line going to the radiator?Before this, did the transmission shift hard when first putting it into gear or while it was shifting?
MY JEEP'S SECURITY SYSTEM IS
There has to be an issue with your key; if no remote starter is installed. If you have an immobilizer bypass interface installed for a remote starter, it could be interfering with the manufacturer key.
I have a Python 1500 ESP security system in a 1999
If you have grey keys for your ignition, than the transponder is being bypassed upon remote starting. You will to check for the round RED LED light in the cluster of your dash, if it is flashing upon remote start, that is the best sign that the transponder interface isnt working. When you start it with the key, that RED LED light will go solid then off, to indicate it is an authorized key.
Jeep Wrangler after market alarm
There is a small toggle switch that you have to find out usually this switch is installed under the dash and when you find it put the car key in the ignition switch and turn it to the ON position and move the toggle switch position until you here a beep, some of the aftermarket alarms bring a push button switch, if this is the case just keep press it until you here the siren beep and does it, this way you are disconnecting the alarm or in another words your alarm is in a valet mode.
Install aftermarket alarmin 98 jeep
relays are one way but i would suggest a digital control module that will hook up to data line and comunicate the commands from the remote to the car.. Thes emodules control locks, factory alarms. etc... they work great. you can find the right one from bypasskits.com
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
