20 Most Recent COMPASS 2008 REMOTE START TWO WAY Questions & Answers
I need to know where is locatoring thefuse box for 2008 jeep compss sport suv
Hello Samuel, The fuse box for a 2008 Jeep Compass Sport is located under the hood & on the drivers side. Here is a link. http://www.carcarekiosk.com/video/2008_Jeep_Compass_Sport_2.0L_4_Cyl./fuse_engine/replace Good luck. Andrew Replace Fuse 2007 2010 Jeep Compass 2008 Jeep Compass Sport 2 0L 4 Cyl
2/2/2015 6:50:12 AM • COMPASS 2008... • Answered on Feb 02, 2015
Turn signals won't work and headlights stay on.
I am having the same problem. Did you ever get it worked out? I would appreciate any help you might be able to give me.
Thanks,
Robert
[email protected]
10/5/2010 1:43:02 AM • COMPASS 2008... • Answered on Oct 05, 2010
I need some explanation about
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
1/23/2019 10:07:48 AM • Jeep Vehicle... • Answered on Jan 23, 2019
Where is a pcm on a 1987 jeep cherokee
Passenger side on the firewall..
6/5/2014 7:30:58 PM • Jeep Vehicle... • Answered on Jun 05, 2014
My 2009 toyota camry hybrid has a great heating system until I am stopped in traffic and then it blows cold air. What can I do to fix it?
do you notice this when your going up hills too? like it blows hot air if you have it on but if your not goin up hill it doesnt? i had the same thing when the gas pedal was down the heat would work and had to replace the reservoir for the coolant or something else check your coolant level too...just remember some cars run with different colored coolants than others
4/22/2014 5:31:20 AM • Jeep Vehicle... • Answered on Apr 22, 2014
Location of PCM on a 1986 jeep cherokee 4.0
Hello it should be located on passengers side under hood on the fire wall behind coolant tank.
4/13/2014 12:23:22 PM • Jeep Vehicle... • Answered on Apr 13, 2014
While AC starts the noise come from engin. While
make a video of the issue
10/3/2013 5:49:56 PM • Jeep Vehicle... • Answered on Oct 03, 2013
Tranny fluid hose explodes
Is this the cooling line going to the radiator?Before this, did the transmission shift hard when first putting it into gear or while it was shifting?
8/3/2013 8:05:19 PM • Jeep Vehicle... • Answered on Aug 03, 2013
MY JEEP'S SECURITY SYSTEM IS
There has to be an issue with your key; if no remote starter is installed. If you have an immobilizer bypass interface installed for a remote starter, it could be interfering with the manufacturer key.
5/25/2011 3:28:21 AM • Vehicle Parts &... • Answered on May 25, 2011
I have a Python 1500 ESP security system in a 1999
If you have grey keys for your ignition, than the transponder is being bypassed upon remote starting. You will to check for the round RED LED light in the cluster of your dash, if it is flashing upon remote start, that is the best sign that the transponder interface isnt working. When you start it with the key, that RED LED light will go solid then off, to indicate it is an authorized key.
8/21/2010 3:13:06 PM • Vehicle Parts &... • Answered on Aug 21, 2010
My alarm doesnt work, i can not lock or unlock the
maybe your control is not sending the information for the alarm just blinking. you can go to autozone to check your control, ask for help.
3/29/2010 7:17:03 PM • Vehicle Parts &... • Answered on Mar 29, 2010
Jeep Wrangler after market alarm
There is a small toggle switch that you have to find out usually this switch is installed under the dash and when you find it put the car key in the ignition switch and turn it to the ON position and move the toggle switch position until you here a beep, some of the aftermarket alarms bring a push button switch, if this is the case just keep press it until you here the siren beep and does it, this way you are disconnecting the alarm or in another words your alarm is in a valet mode.
2/1/2010 2:05:10 PM • Vehicle Parts &... • Answered on Feb 01, 2010
2answers
Engine starts momentarily then shuts down,
Hello! I need the year, and model in order to solve your problem..
I am here!.................Guru..............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1/10/2010 1:21:34 AM • Vehicle Parts &... • Answered on Jan 10, 2010
Install aftermarket alarmin 98 jeep
relays are one way but i would suggest a digital control module that will hook up to data line and comunicate the commands from the remote to the car.. Thes emodules control locks, factory alarms. etc... they work great. you can find the right one from bypasskits.com
8/22/2009 2:50:17 AM • Vehicle Parts &... • Answered on Aug 22, 2009
Remote start not working after installation
this could be a lot of different things.... email me at [email protected], and i'll give you my ph# and talk you through it if you want. im an MECP First Class Certified installer with over 10 years of experience, by the way.
1/22/2009 7:27:26 PM • Vehicle Parts &... • Answered on Jan 22, 2009
COMPASS 2008 REMOTE START TWO WAY Logo
4 questions posted
Top Jeep Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Jeep Vehicle Parts & Accessories
Most Popular Question
need know locatoring thefuse box 2008
  • Vehicle Parts & Accessories
