20 Most Recent
Panasonic KX-TA308 Phone Questions & Answers
I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
6/6/2014 1:47:49 PM •
Panasonic...
Answered
on Jun 06, 2014
KX TA308 how to disable 2 locals Ring sametime
There are two possibilities, you have to check to confirm. Either the two were physically wired in parallel or through programming they were configured to ring simultaneously. Start by checking if the two were physically wired in parallel. One way would be to establish how many extensions you have altogether and is it equal or less than the total number of extension ports available on the KX-TA308?
4/10/2014 4:36:41 AM •
Panasonic...
Answered
on Apr 10, 2014
My handset is locked. I
The unlock procedure for a phone that has been locked is to dial *77 and the lock code on the intercom. If it was locked by the attendant, then the attendant has a procedure to unlock it and, in fact, has to unlock it.
Carl
11/6/2013 6:08:50 AM •
Panasonic...
Answered
on Nov 06, 2013
How can I change line
Why? A TA-308 as well as all Panasonic systems run on 24 volts, even the TDA/TDE. The quickest way to do that, and very expensive, was a Proctor Long Line Adapter (46222/46224). The only time we ever had to use one was to bring up the line voltage of a Merlin Legend extension to interface to a Panasonic system we were using as a factory intercom. The intended purpose is for off-premise extensions as they provide high voltage ringing and protect the system it's attached on.
Proctor is long gone, but Viking Electronics makes an exact replacement. Here are the specs
http://www.vikingelectronics.com/products/pdf/lla-4.pdf They also run about $500 for 4 ports.
Carl
8/29/2011 12:31:08 PM •
Panasonic...
Answered
on Aug 29, 2011
My problem is that i
Panasonic made 2 TA-308's, one for the US market and one for worldwide. It's similar in operation to the 624 and those manuals are available on the internet. There's not much to them, it has 11 modular jacks and 2 1/8" (350mm) jacks on the side (top) that interfaces to the 3 lines and 8 phones with music and paging ports. At the least, there's an installation manual and a user's manual. Later systems added a separate programming manual.
Carl
6/6/2011 12:47:42 PM •
Panasonic...
Answered
on Jun 06, 2011
