20 Most Recent
Little Tikes Totsports Easy Score Basketball Set Questions & Answers
I need a replacement net
little tikes sells it on their web site
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=7865
No pin
Chances are, you can probably pull a relative "fake" pin together easily enough at your local hardware store. Simply measure the length the pin Should be(the point between holes), and the width of the hole, and take those measurements into any lowes or home depot. From there, either pick up a pin if they have one, or a bolt and a wingnut, and you'll be all set! Ensure that in either case, you get a pin that is at least one inch longer than the hole's depth, to give the pin some wiggle room.
Little Tikes (vintage) Ride-On Train doesn't drive forward?
Question edited for clarity.
Question moved from Cars and Trucks category.
If it runs backwards, then the problem but be the forwarding part of the controller. Usually your local Model Shop will know a repairer, or they might undertake it themselves.
