20 Most Recent
Contour Design 00903-0 SurfaceSound Compact Bluetooth Speaker Speaker System Questions & Answers
I threw away my instructions on my Contour Design BlueTek
Here are the instructions from the manual for my Contour Design SURFACE SOUND COMPACT (with minor editorials)
To initiate pairing:
- Place the bluetooth device and your mobile phone within 0.3 meter (1 foot) of each other - I prefer to place both on a table infront of me
- Switch on your phone and select it Bluetooth discover mode (you'll have to figure this one out on your own!)
- Immediately after turning the bluetooth device on (ie. lifting the microphone), press and hold both the TALK button and the VOL + button for about 5 seconds until the indicator light flashes red and blue alternately and a sound can be heard in the speaker - I had trouble getting it to co-operate once it started into the seeking handset mode of beeping, so try to press the two buttons before all that beeping starts
- Once the mobile phone detects the carkit, a "contour SSC" message will be displayed. Follow the phone instructions to accept the pairing. The PIN coade (or passkey) is 0000, then press "yes" or "ok". I assume the PIN code is the same for all of them, as the manual appears mass printed.
If the pairing was successful, the indicator light will switch to blue and flash slowly. If you haven't started the discovery mode within 5 minutes, it will stop. In this case, you must start the pairing again as step 3 above.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
