20 Most Recent
Homelite ZR40502 Factory-Reconditioned 26cc MightyLite 20" Gas Hedge Trimme Questions & Answers
Stales out
You will need to take to a shop and have the technician adjust the carburetor. Plus I recommend mixing your fuel mixture at 40:1(3.2 oz 2 cycle oil to 1 gallon of gas) instead of the 50:1(2.6 oz 2 cycle oil to 1 gallon of gas). If your fuel mixture is over 30 days old, it is considered bad gas.
All the manufacturers I have heard from this year have made this knowledge known.
Good Day.
Homelite trimmer zr40502
Do you have fresh gas? If so is the mix right? If you can get to the carb easy spray some carb and choke cleaner in it. Check the gap on the new spark plug. The gap should be located somewhere in the manual. The big problem is making sure that the mix is right. To much oil in gas will foul plug smoke like crazy and foul the plug and hard to start. Not enough oil and you can seize it up.
Good luck let me know if this helps.
roundo4
Need a fuel line diagram for my Homelite vac attack 2 model UT09834
You should have 2 lined coming from tank. A return and feed. Normally the return is the lowest positioned outlet on the carb, and the feed is at the top. When pumping the purge bulb take the gas cap off tank, and you should see fuel being returned to the tank from the return line. If not, switch the lines on carb. If still not returning fuel to the tank, you will need to pull the carb and inspect the metering and fuel pump diaphrams.
What is the spark plug gap for a homelite 2700psi pressure washer with champion eco 322
The recommended spark plug gap for a Homelite 2700 PSI pressure washer with a Champion Eco 322 spark plug is 0.030 inches.
but in my opinion, It's always best to consult the owner's manual or contact the manufacturer for the most accurate and up-to-date information regarding the proper spark plug gap for your specific pressure washer model.
good luck
What gas does a Homelite 16 " Ranger chain saw use
The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle engine oil, and the manufacturer recommends the use of a two-cycle oil that contains fuel stabilizer to keep the mixture fresh if you are not using it immediately.
