It sounds like you have the possibility of a couple of things going wrong here. It could easily be a board issue based upon what you are saying. However, it could also be a pump issue because you are having limited success with filing the tub up half way. The best suggestion is to have a spa technician come out to assist you in determining what exactly is going wrong here.
You really have not provided enough details on the problem to help you diagnose exactly what is going on here.
Thank you for posting your question here on Fixya.com. With your meter check to see if the motor is still getting voltage when it kicks off. If it is the motor needs servicing. If not, look for which component (such as the relay) is dropping line voltage and replace it. If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! John
Amazon.ca
https://www.amazon.ca > Fair-Oaks-Standard-Skimmer-...
Allows you to repair your rusted skimmer area without replacing entire pool. Pool walls are made of galvanized steel which will eventually rust. This repair ...
Rating: 4.7 · 137 reviews · $131.45 · In stock
Missing: Azteck ' Show results with: Azteck
Question edited for clarity.
Question moved from Computers category.
Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power.
https://www.google.com/search?q=lifesmart+ls350+plus+220+volt
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need.
That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on.
Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard.
https://www.google.com/search?q=Maax+461+Heater
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out.
So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
Question edited for clarity, spelling of maker and order of 'make model (what it is)'.
Question moved from Sewing Machines category.
It appears to be a New Zealand product made in Australia. We are in North America. This link should find you one and also has a link to the maker.
https://www.google.com/search?q=+leisurerite+GL2000+spa+replacement+cover
