20 Most Recent
RTO 1 Siemens Pure 500 Open Fit Hearing Aids Aid Ric Bte Questions & Answers
How to clean the domes on hearing aids
Take the domes off, wash them out or use a pipe cleaner to poke out the wax. If you have washed them, make sure they are thoroughly dry before you put them back on. When you put them back on make sure they are firmly on the receiver tip or you will be taking a trip to A&E to get it removed from your ear canal.
Siemens Pure 501 RIC
It could be a receiver issue, the cord, it might be a faulty receiver or alternatively it could be plugged with wax or badly affected by moisture. Receiver issues are relatively common with Siemens, if you have cleaned out the tip and are confident it is not a moisture issue, the receiver has failed. it is an easy fix and your audi should be able to change it out on the spot.
It's exactly like the guy says on the left:
The receiver, the piece you call the cord is either blocked with wax or dead. Check the very tip of the receiver for wax detrius, if there is some remove it and see if you can hear. If not you may need to get a new receiver.
R. Hearing aid has died for the 5th time.
RIC instruments are quite delicate, the receivers often fail, however it is a quick fix to replace them. Have you tried a drying kit, a drying kit is essential to maintain RIC or RITE instruments particularly during the summer months. Go back, get the receivers changed and ask for a drying kit.
Siemens charger for hearing aids
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
Can come out when i remove glsses or take off
Hi Jan3630,
The instruments you show in the picture appear to be ear inserts rather than custom ear mold. Customs can also be small.
You may consider having a local Hearing Health Care Professional advise you as to the feasibility of replacing your sound tubes and inserts with Custom ear-molds.
These will have a better chance of staying in the ear when you are doing the activities you described. Please advise if you find info helpful. Thanks for contacting FixYa.com
Siemen 500, I can't get
I think you need to plug it into the tv instead since the sound is coming from the tv's speakers and not actually from the dvd player or? how are the things set up there.
Motor bike qingqi
Hi Alan, any chance of a photo of the motor and read transaxle ???
Regards
Rob
www.gewizrepairs.co.uk
